01 Excursion grimlens - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 20 Old 01-17-2014, 05:52 PM Thread Starter
04SSHD's Avatar
I just picked up a 2001 Excursion, and had a few issues I wanted to run by you guys. Wondering if they're common problems and quite possibly have common fixes.
First issue is the power door locks, when I hit the button I hear all of the actuators actuate. But none of the lock tabs move up or down in the door panels. They seem like they try but don't actually move enough to lock/unlock the door.
The next issue is the parking sensors don't work. The button on the dash to turn them off is illuminated for OFF. If I push the button it quickly flashes, then goes right back to off. Seems like a fault of some sort...I'm kind of lost here. I have parking sensors on my 03 6.0 and they're nice to have, but I have no idea why these ones don't work.
Next issue is my lift gate doesn't lock at all. Power door lock button won't lock it, and the key won't lock it. I can insert the key and turn the cylinder to lock it. But it will never actually lock. I'm guessing I need to dig into the lift gate to figure this one out, any tips or tricks?
I just realized that my truck is actually "he". What girl do you know likes to be stroked and blown?
04 F-250 FX4 CCSB 6.0L PSD, Lariat Conversion, 05 Clip, 08 Rear, 08 Mirrors, Banks TBE, 8" Coilover Skyjacker, 38" Toyo MT's, XD Revolver 20" 75k
03 F-250 FX4 SCSB 6.0L PSD, 4" Lift, 35" MT 117k
01 Excursion Limited, V10, 05 Clip, 20" SuperDuty 5 spokes
96 F-250 x-cab 7.3L PSD (SOLD)
04SSHD is offline
post #2 of 20 Old 01-17-2014, 07:36 PM
I have a same lock problem but, only with the driver side rear door. I am just living with it for now. The rear lift-gate lock problem was discussed here a while back. I believe the person removed the interior panel and only required the linkage to be lubricated to make functional. What kind of mileage to do get from the V10?? I get 16 - 18 depending on driving/warm-up.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
post #3 of 20 Old 01-17-2014, 09:31 PM Thread Starter
04SSHD's Avatar
Thanks for the reply, I'll do a quick search for the rear gate info, hopefully I can find it.
I honestly don't know what kind of mileage the V10 gets, it came with half a tank in AZ when I bought it and it's still got over a quarter tank left from the drive back to NV.
I hear they get about 8-10mpg
04SSHD is offline
post #4 of 20 Old 01-17-2014, 10:04 PM Thread Starter
04SSHD's Avatar
Found threads with the rear lock info-
rear hatch lock not working
Locking rear door/hatch
04SSHD is offline
post #5 of 20 Old 01-18-2014, 05:58 AM
Garage
Door lock actuator problem is well covered in previous posts, as well. Don't know how to tag links, though!
Shane is offline
post #6 of 20 Old 01-18-2014, 06:02 AM
Garage
Something about removing a resistor or using foil to bypass it will make the actuators stronger. Something like that. Replacing actuators is supposedly very expensive due to having to buy the whole assembly.
Shane is offline
post #7 of 20 Old 01-18-2014, 07:06 AM
When I bought my 2000 Ex, none of the locks worked and had the same symptoms as yours. YouTube has videos on how to fix yours, but I bought all 5 actuators off of eBay pretty cheap. They aren't terribly hard to swap out, and you can do all of them in a couple hours.
As far as the back up sensors go, if one doesn't work, none of them will. Have someone get in the driver's seat, turn the key forward but don't crank it over. Have them put their foot on the brake and put the vehicle in reverse (all while the vehicle is not running, mind you). Now, you go behind the vehicle and put your ear up to each sensor. There will be a clicking coming from the one or ones that do work. The one or ones that are not clicking are the failed component. Replace accordingly and that project is completed!
I've never had the lift gate failure to lock problem, so I can't help you with that one. Sorry! Good luck!
Rahn is offline
post #8 of 20 Old 01-21-2014, 07:18 PM Thread Starter
04SSHD's Avatar
I tried this, all 4 sensors made a clicking noise. Would it be safe to assume all are good?
04SSHD is offline
post #9 of 20 Old 01-22-2014, 01:23 PM
You got me there....that is what I did on mine and what worked for me. Follow the link below for some additional information I found.
backup sensor connectors (repair how-to) - Ford Truck Enthusiasts Forums
Rahn is offline
post #10 of 20 Old 02-01-2014, 08:37 PM Thread Starter
04SSHD's Avatar
got the door actuators replaced and all my door locks work again, need to do the liftgate next!
04SSHD is offline
