HELP!!!!!! - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 16 Old 01-17-2014, 09:39 AM Thread Starter
HELP!!!!!!
I have a 2000 ex with the 7.3 with 174000 miles, I was having problems with it shutting off randomly with out warning j changed the cps, I was good for about 2 weeks and then started doing I again I googled some more and looked up the the right codes that it thru and everyone said it was my ipr or ipc, so I changed both it has done good until today, we was driving she jerked around and then shut off, she threw two codes p0301 p0302, both misfire codes, my question is with new icp and ipr what could cause this? And how do I trouble shoot, please help
Texanexcursion is offline
post #2 of 16 Old 01-17-2014, 10:34 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
I'm no diagnostic pro, but it could be the uvch, have you done the 50 cent mod or checked the uvch?
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #3 of 16 Old 01-17-2014, 11:19 AM
usteffenhagen's Avatar
It's uncommon for the uvch to come disconnected at both sides. When mine did it it was on the passenger side and it ran but very roughly. Slipped a quarter in both sides though have you looked up those codes? If it was the uvch it shouldn't throw those codes. But I could be wrong too...
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 16 Old 01-17-2014, 11:25 AM
Just looked it up. It says those are misfires on cylinders 1 and 2. Have you checked compression lately?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #5 of 16 Old 01-17-2014, 11:27 AM Thread Starter
Not trying I be dumb here but what is the uvch and where is it
post #6 of 16 Old 01-17-2014, 11:28 AM Thread Starter
No I haven't, I don't have anything to check compression with
post #7 of 16 Old 01-17-2014, 03:20 PM Thread Starter
Ok so I went back out to the truck, now the wait to start is flashing along with the over drive off and my service engine soon light and there is some strange like humming and clicking but can't tell if t is from the back of the engine or the firewall,
post #8 of 16 Old 01-17-2014, 08:52 PM
WTS light flashing? I know that if it doesn't come on it is a PCM issue. I'm stumped... I'll look and ask around if I have time tomorrow
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #9 of 16 Old 01-18-2014, 03:06 PM Thread Starter
I have heard a lot of things about the under valve cover harness, could that be the cause of my misfires, what about my idm also
post #10 of 16 Old 01-18-2014, 05:19 PM
Possibly. It's simple to get to. You are familiar with the uvch right?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
