Looking for frame mounted steps, nerfs, or running boards - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 4 Old 01-16-2014, 03:56 PM Thread Starter
Hello, 2000 X Limited, 4x4, lifted, currently has the chrome oem boards. Passenger side has fellen off of front 2 mounts, far forward mount is weak/wobbly, middle mount is strong, back mount is so terrible I can rotate it 180 degrees. Drivers side is starting to weaken as well. (Ah the joys of living in the rust belt and having rusting rockers)
Anyhow, long story short, due to the poor shape of pinch welds, I am looking for something I can bolt to the frame, I have seen some stuff for F250/F350 that is frame mount (ranchhand, smittybuilt, westin, nfab) but nothing for the X.
I am ok with hoop steps or full boards, anything to make it easier for wife and kids to climb up into the tall X.
I am wondering maybe if the stuff for f250 would mount up to frame on X? Maybe the ranch hand hoop steps? The front seems plausible, back doors I am more uncertain about.
Thanks in Advance
yotatoy is offline
post #2 of 4 Old 01-18-2014, 08:17 AM
I think I have read that the newer crew cab OE stuff will work (length wise) but you may have to adapt and overcome with the aftermarket stuff....maybe the aftermarket tech lines could offer some better answers.
Rahn is offline
post #3 of 4 Old 04-08-2014, 08:58 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
Summit Racing has the Smittybilt step bar, with single additional step.
I like it, but can't quite justify $400 yet...
May just wind up making my own.
http://www.summitracing.com/parts/sm...view/make/ford
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #4 of 4 Old 04-09-2014, 07:15 AM
scagle1's Avatar
That looks like the same mount style as factory tying into the sheetmetal not the frame. I got NFAB in the same setup and it uses stock mounts as well , not the frame.
If fab skills are worth a flip id get a stick or two of 2 7/8" oil field pipe ($30) , cut it in half and have some flat stock that you can drill thru and thru the frame rails for the mounts. Some angled cuts should allow for welding of flat stock to angled cut pipe welded to straight pieces. Rhino line it and call it a day , Under a $100 dollars if all DIY , cant imagine a shop being more than $150 to weld up if you give measurements and material , then you just need to drill frame rail and mount. Something along the lines of pic below , they however brought the step out again
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
