K&N Air Intake Kit and using a different filter? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 12 Old 01-10-2014, 03:49 PM Thread Starter
Question K&N Air Intake Kit and using a different filter?
I'm a noob to Diesels, so please throw me a bone on this one. 2002 7.3 Excursion, 2wd. 148k miles.
I just bout it a couple days ago and it came with a K&N air intake kit (filter, heat shield, and pipe run) installed. From what I have been reading, K&N anything is not the best setup for a 7.3. I'm thinking about going with the Ford AIS kit, but really do not want to shell out the money unless I have to. So, my question is can I keep the K&N kit, but use a different filter on it or should I go ahead and do the whole thing? Recommendations?
Thank you for your help!
hbscott2004 is offline
post #2 of 12 Old 01-11-2014, 06:58 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Keep the K&N intake pipe, Call Riffraff and get their 6637 filter. You can get one at NAPA or any fleet store. Riffraff is the cheapest by far. Good to get 2 at a time because of the shipping cost. I think they are $28.99 but still cheaper with shipping than anyone else I find
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #3 of 12 Old 01-11-2014, 07:03 AM
scagle1's Avatar
Keep the pipe and heat shield , toss the filter , buy an amsoil filter , they make an exact match for the K&N with the screw and all. Been there done that. I don't recall the part number but do know I've posted it up in the forum a few times so it is searchable. The DIY filter will not work with the heat shield so in the thoughts of keeping it nice looking I would avoid that route.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #4 of 12 Old 01-11-2014, 07:17 AM
scagle1's Avatar
Try this out on Amsoil's site , should be the right one. Few dollars more than a DIY filter , except yours will be cleanable and still look like it belongs. Kind of a no brainer.
Amsoil filter replacement (for a K&N filter pack). EaAU-4095/ K-N RC-4780
scagle1 is offline
post #5 of 12 Old 01-13-2014, 05:05 AM Thread Starter
Thanks for the replies, although I almost got into trouble.....started to spend money at Riffraff that I do not have to spend...ie, things other than a filter LOL!
post #6 of 12 Old 01-13-2014, 05:52 AM
scagle1's Avatar
I can always find an excuse to shop Riff Raff , things ALWAYS wear out.......
scagle1 is offline
post #7 of 12 Old 01-13-2014, 10:55 AM
CSIPSD's Avatar
Why will this not die... There is no issue with the K&N filters... NONE. They use exactly the same 5 layer filters that AFE and S&B use... The issue has been and always will be the way a DROP IN K&N filter fits the factory air box.
Do what ever you want with your filter box, but don't do it because some internet legend that will not go away tells you to.
Beware, the 2000 6637 filter guys will be here shortly...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 12 Old 01-13-2014, 11:09 AM
layson's Avatar
Quoted: 83 Post(s)
yes, I had the dreaded drop in filter in my truck when I bought it. It didn't fit quite right in the stock air box. It would let unfiltered air through.
The filter you have is fine.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 12 Old 01-13-2014, 11:17 AM
Christ Follower
Quoted: 14 Post(s)
I have to agree 100% with CSIPSD. I had the K&N Cold Air Intake Kit on my 7.3 Ex for over 250,000 miles and my turbo looked perfect with absolutely no dusting what so ever. The only reason I switched to the 6637 is because the K&N was stepped on by accident while it was out getting cleaned. Otherwise, I would still have it on.
I would never keep the drop in but the Cold Air Kit worked perfect.
403,000
PHP Hydra
MBRP 4" Turbo Back
Firestone Ride Rite
Derale Atomic Cool
post #10 of 12 Old 01-13-2014, 11:40 AM
CSIPSD's Avatar
Whats scary is Banks still offers a drop in panel filter with there powerpac kits!!!
Joe
CSIPSD is offline
