Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 09-05-2008, 03:16 PM
alsexcursion alsexcursion is offline
Superchips Micro Tuner
I just recently purchased a 2000 Excursion with a 7.3 the previous owner told me he had a Superchips Micro Tuner and ran it on the tow safe mod only, as it was his wifes vehicle. my question is are there going to be any long term problems to be expected?
Old 09-06-2008, 07:24 AM
SD26 SD26 is offline
I had a SCMT 1700 on my E350 on tow mode for over six years. It's not a "hot" tune, per se. Often helps in mileage and the transmission shifts are more logical than the OEM set up. Certainly will wake up the grunt from the engine.
Old 09-08-2008, 01:10 PM
Thanks I appreciate the info.
Old 09-08-2008, 08:55 PM
Soaggydogg Soaggydogg is offline
Your Ex should be fine (with the 1700/1705) but there is a lot more HP that you can safely gain if you desire.
Old 09-08-2008, 09:10 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
had him add gauges
Old 09-08-2008, 09:11 PM
CloverLeafFarm CloverLeafFarm is offline
Tournaments Won: 1
i've had no problems with my superchip on tow setting
Old 10-24-2009, 02:17 PM
strester strester is offline
I have had one on my EX for several years never had a problem. There is a big difference between the stock and even the Towsafe setting.
Old 11-03-2009, 12:11 PM
RustyNCA RustyNCA is offline
Does the towsafe vs tow performance render different MPG?
Old 11-05-2009, 04:26 PM
njneer1 njneer1 is offline
I've had my 1705 on level 2 (tow performance) for over 2 years now with no problems at all. I think the mileage is better on tow performance but I think towing has a 6k lb limit at this setting. Couldn't stand to drive it without it. Seems to work better if I "knock it down" and reload it every 6 months or so......seems to re learn some bad trans shifting habits over time.
Old 11-06-2009, 01:50 AM
Yes there is a difference, but you have to keep off the gas peddle. 6000lb limit on setting Tow Perf.
