00 fire dept ex - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 4 Old 12-10-2013, 07:47 PM Thread Starter
Harleytruck04's Avatar
00 fire dept ex
Hey guys we have a 00 2wd ex that is acting like you are stomping the brake pedal when you put it in reverse and turn full lock in either direction. I have no idea where to look cuz I'm a 6.0 guy!!lol what could it be????
Harleytruck04 is offline
post #2 of 4 Old 12-11-2013, 07:41 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
I would jack up the front end and check the wheel bearings. Simple to check with the tires on, just grab tires at 12 and 6 o'clock then 9 and 3 and try to move the wheel. If there is any wobble, the bearings are bad.
Are there larger than factory tires? Any place the tire could be grabbing?
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #3 of 4 Old 12-11-2013, 08:26 PM Thread Starter
Wheel bearings check good and tires are stock size. I've checked all in wheel wells and don't see anywhere that they rub.
post #4 of 4 Old 12-12-2013, 09:31 AM
Cllake's Avatar
Are your brake lines binding?
Cllake is offline
