Autometer or Glowshift - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 30 Old 11-28-2013, 01:57 AM Thread Starter
im looking to get a pyro, trans temp, and boost gauge. I havent had any dealing with either company so not sure which is best to use? also any other gauges you guys would recommend getting?
mrasiankix is offline
post #2 of 30 Old 11-28-2013, 03:29 AM
I have the glowshift and the only thing I do not like is the backlighting is so bright that it makes it hard to see past them because of the glare. They are mounted on the post and I have them on the low setting, I am probably going to tint the faces of the gauge.
Sent from AutoGuide.com App
DeGolyerent is offline
post #3 of 30 Old 11-28-2013, 03:36 AM Thread Starter
their prices are alot lower than autometer but im worried about quality.
post #4 of 30 Old 11-28-2013, 06:00 AM
chevelless414's Avatar
I have the auto meter GS series. Its a black face and green led lighting looks great in my opinion.
2002 Excursion 7.3
6637 filter
gauges
v&b code spring swap
hellwig rear sway bar
4" mbrp exhaust
DP- Tuning
wicked wheel
ebpv delete
chevelless414 is offline
post #5 of 30 Old 11-28-2013, 06:29 AM
shiz big red's Avatar
I started out with the glowshifts but hated how bright they were and my trans temp and egt stopped working they were reading way wrong so I went to autometers I've had them for about a year with no problems I would say spend the extra cash and go for the more reliable autometers.
shiz big red is offline
post #6 of 30 Old 11-28-2013, 06:58 AM
speedracer7c's Avatar
dont waste you time with the glow shifts. My boost gauge is so erratic. Sometimes it reads sometimes it doesn't.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #7 of 30 Old 11-28-2013, 07:23 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
I like the ISSPRO EV2 better than both. But from your two choices, I'd get the AutoMeter's
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #8 of 30 Old 11-28-2013, 08:08 AM
gotta_gofast's Avatar
Quoted: 62 Post(s)
I run the autometer factory match gauges (the needle and number font match the factory dash gauges). I've used glowshi t gauges only to have them fail after a season or two.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #9 of 30 Old 11-28-2013, 08:17 AM
HRFD438's Avatar
Idk why everyone's had problems with glow shifts. I've had mine in for almost 2 years and never had a single problem with them.
2002 F-350[/COLOR]
LIFTED 10" :: 38X15.50X20 MUD GRAPLERS :: INTAKE :: 4" TB EXHAUST :: SAVING FOR COMPLETE BUILD
HRFD438 is offline
post #10 of 30 Old 11-28-2013, 08:28 AM
dnf12908's Avatar
Quoted: 34 Post(s)
This is the complaint I have with them, too. I did tint mine but the downside is that it's not bright enough to read them in bright sunlight.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Edge Insight monitor
Harley headlights w/Gensii LED bulbs
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
