New to me 2000 ex - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 16 Old 11-24-2013, 09:38 PM Thread Starter
New to me 2000 ex
So I finally found one I picked up a 2000 excursion with 110ish. It's want I had been looking for.
We all know the good 7.3 powers toke bla bla bla
Now for the bad cuse those r the only things that matter really when buying a use truck
Paint is horrific ,every panel needs to worked over some more then others ,the roof is the worst but it all is fixable and it helps that auto body is my line of work
The inside is not the worst but the carpet needs to be replaced (kids) and it is 13 years old
But here we go alet the build begin
Novaex is offline
post #2 of 16 Old 11-24-2013, 09:39 PM Thread Starter
Here's the roof
Novaex is offline
post #3 of 16 Old 11-24-2013, 09:47 PM Thread Starter
So the first thing I'm doing is exhaust my plan is to put on diamond eye 5in turbo back no muffler but I can only find one for 1999-03. f250/f350 I have read that it could work I had the 04 - 07 kit on my 05 cclb no problem but I'm talking about a hole different truck so if any one has input please let me know
Novaex is offline
post #4 of 16 Old 11-24-2013, 09:50 PM Thread Starter
And I will be put my plow on this truck but I want to lift it a little don't know if I want to put a 4 in kit or X codes let me here what has worked for u
Novaex is offline
post #5 of 16 Old 11-29-2013, 04:17 PM
f350powerstroke's Avatar
home dept rents out steam cleaners. did a pretty good job with my old interior. then i used tide, lil water and a brush for the real tough stains.
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #6 of 16 Old 11-29-2013, 09:02 PM
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
I run X codes with my boss V plow.
Also this is what I orderd for exhaust haven't had time to put on yet.
Diamond Eye | K4332A-RP | 4" Turbo-Back No Muffler Single AL: 2001-2002 Ford 7.3L Powerstroke Excursion
Also the Bild thread on my truck.
My 01 X Nightmare repair and Future Mods
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
post #7 of 16 Old 11-30-2013, 07:53 AM Thread Starter
My friend is a mobile detailer we gave his steam cleaner a shot but The carpet is past the point of no return so just going to replace I found whole truck for $249 brand new
Novaex is offline
post #8 of 16 Old 11-30-2013, 02:50 PM
RAMKILLER97's Avatar
When I bought my 4" MBRP tb from XDP they told me that they are the same exept for where it comes over the rear axle. Due to the Excursions larger fuel tank the pipe is bent more than that of a super duty. They called MBRP while I was there to confirm it as well. Now am I saying a super dutys flat out wont work, no, but buying an Excursion specific exhaust will work a lot better, and won't require any modifications.
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
post #9 of 16 Old 11-30-2013, 05:12 PM Thread Starter
Thanks that was the answer I was looking for I will get the 4 in that way it just bolts up and it $150 less then the 5 inch
Novaex is offline
post #10 of 16 Old 11-30-2013, 09:29 PM
ramkiller where are you stationed?
novaex where are you buying the carpet from? mine is shot too and trying to find a thick factory replacement carpet has been hard
greasemykey is offline
The Following User Says Thank You to greasemykey For This Useful Post:
Novaex (12-11-2013)
