Is the Timken Front Wheel Hub Assembly worth the extra money vs 1A Auto or other? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 15 Old 11-18-2013, 11:16 AM Thread Starter
Woody_PSD's Avatar
I need to replace the front passenger wheel hub assembly on my X. I am looking around at the available one from online sources as well as my local Autozone and I'm wondering what others experience has been with the less expensive (cheaper??) wheel hub assemblies.
Timken seems to be the expensive (nice?) ones, and also comes with a 3yr warranty, which are about $185.
The other two options are the duralast 1yr warranty ones for about $115 & the 1A Auto set (both fronts) for $175, which has a 2yr warranty.
Being tight on money I have to ask has anyone used the 1A Auto versions and if so, thoughts?
I really don't want to have to do this job again in 45000 miles just because I bought cheap parts.
Should I just bite the bullet and buy the Timken or give the 1A Auto a shot. I actually don't think the duralast is even worth my time...
Thanks for the advise in advance.
2001 Excursion Limited 7.3 PSD
4" Exhaust, Ford AIS Filter and Box
DP-Tuner F5 - Current Chip
Diablo Chip (not being used)
Superchips 1705 tuner (My code reader)
Broken Tranny as of 01/29/2011 --> New John Wood Trans shortly after. So far it's been awesome, spendy, but awesome.
Tire: Michelin LTX M/S2 LT275/70R18
**First PSD - Purchased 1/2/2008
My Site: mxguy.com
My Forum: allthingsmoto.com
Woody_PSD is offline
post #2 of 15 Old 11-18-2013, 08:07 PM
Gaius's Avatar
Quoted: 41 Post(s)
Timken for sure. I certainly wouldn't get the 1A auto.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #3 of 15 Old 11-18-2013, 09:25 PM Thread Starter
Woody_PSD's Avatar
Experience or opinion? I'm leaning toward what you suggested, but I'd like to hear some experiences if possible... might not be.
Oh and thank you.
My Site: mxguy.com
post #4 of 15 Old 11-19-2013, 04:17 AM
Macon's Avatar
Timken. For $10 more you get known better and less worry. I have no experience with 1A Auto, but everything Timken I've used has been great.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #5 of 15 Old 11-19-2013, 08:43 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
And worth it. Bearings are definitely an item where you get what you pay for. Experience, not opinion.
Speaking from my experience with all things I ever bought with the "Duralast" name on it from from Autozone is that they charge you double what it is actually worth because it WILL fail in the warranty period, so plan on this one failing within 2 years and doing this job again. When you run your first failed Duralast bearing back to Autozone, keep your receipt handy and they are happy to hand over another replacement. This replacement will also fail again in under 2 years, but since this one is a replacement for a failed unit, there is no warranty.
So you get the absolute joy of doing this job 3 times instead of once because you wanted to "save" $70. Not really saving yourself, in fact you are costing yourself MUCH MUCH more by going the Autozone "Duralast" route. I view Autozone and their "Duralast" brand as about the bottom of the barrel and only go to Autozone for National name-brand things like oil, chemicals and waxes.
Zero experience with 1A Auto bearings. For $10 more to get the Timken bearing, I wouldn't bother with them either.
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 15 Old 11-19-2013, 10:08 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Just curious, your whole hub is bad or are the bearings going out? Because you do know you can just replace the needle bearing in the hub? Its like 12 bucks for a new bearing
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 15 Old 11-19-2013, 11:42 AM Thread Starter
Woody_PSD's Avatar
Thank you for all of your thoughts. I appreciate the experience all of you have and thank you for sharing it with me.
As far as what bearing is shot, I am not sure as I've not taken it apart yet, I just know from jacking it up and spinning the wheel that something's not right.
Do you have a link to an article about the needle bearing replacement? That would certainly be waaaay more economical if that's all that's wrong.
My Site: mxguy.com
post #8 of 15 Old 11-19-2013, 11:51 AM
Chapter Director
Quoted: 5 Post(s)
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Right there, he just services the bearing but replacement is just one extra step of removal and installation of new bearing part number is on the page
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
The Following User Says Thank You to Rammstein1224 For This Useful Post:
Heavy_GD (11-19-2013)
post #9 of 15 Old 11-19-2013, 03:59 PM Thread Starter
Woody_PSD's Avatar
Awesome! thank you!!
My Site: mxguy.com
post #10 of 15 Old 11-19-2013, 04:44 PM
Chapter Director
Quoted: 5 Post(s)
No problem just go ahead and send me that extra 100 bucks you were going to spend jk bud
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
