wobbly goblin - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 1 Old 11-06-2013, 03:07 AM Thread Starter
Exclamation wobbly goblin
Hi everyone, I am new to the forum, I have a 2000 Excursion diesel with a 7.3 engine. I have a handling problem that comes and goes but has gotten worse this week.
I replaced both wheel bearing units with Timken last weekend and the handling is significantly better, but if I turn the wheel tight in either direction, the steering wheel will not center and the front tires will turn either direction slightly so I am always correcting it.
The truck has 185k and I think it could be the steering box, I've never adjusted it, never needed to until now. I wonder how much difference adjusting the box will make or if I should I just replace it. Maybe the valve controlling the power steering pressure is hanging up or defective. I want to know if the box is something I could buy used or are the boxes problematic. oops sorry the truck is stock height and tire size running bf goodrich ko bone stock. thank you regards,Erich
erich norteman is offline
Tags
odin , the mighty o , wobbly
