Cold Running problems - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 21 Old 11-03-2013, 01:06 AM Thread Starter
Twawsi's Avatar
So my EX has started to have cold running problems and I come to you all for help. Let me explain.
When the motor is cold, once started the vehicle has no power for the first few hundred yards. Once past that, it runs fine. This has started happening since the morning temps started getting in the 70's which I do not believe has anything to do with it, but just adds more info. I did notice that around this time, the milage dropped.
What I have done so far.
1. Read, and re-read the boards for ideas
2. Replaced the EBPV Sensor
3. Replaced the EBPV tube
4. Cleaned the soot out of the bracket that both the above connect to
5. Scratched my head why nothing changed.
Any ideas?
Grazie
Twawsi is offline
post #2 of 21 Old 11-03-2013, 11:28 AM
miked.'s Avatar
glow plug relay. not starting on all cylinders. maybe?
miked. is offline
post #3 of 21 Old 11-03-2013, 12:11 PM Thread Starter
Twawsi's Avatar
GPR (edit-meant GPCM) is working fine. It checked out with a DVM
Twawsi is offline
post #4 of 21 Old 11-09-2013, 09:18 AM Thread Starter
Twawsi's Avatar
Ran the codes on it today and the came up with a P0603 KAM error. I do not have a Tuner so that's not it. The fuses are good, any other ideas, anyone?
Twawsi is offline
post #5 of 21 Old 11-09-2013, 09:31 AM
Rodslinger's B1TCH
Worn injectors. Do an oil change using rotella t6, it will make a world of difference.
steve604 is offline
post #6 of 21 Old 11-09-2013, 01:23 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
is there white smoke on startup?
also if your ebpv is closed when you try to drive you will have no power. this may be whats happeneing.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #7 of 21 Old 11-10-2013, 01:42 AM Thread Starter
Twawsi's Avatar
Truck has a fresh oil change already. At $12 a quart over here in EU, I'm not about to do that again right now.
No white smoke on startup.
I was thinking the same on the ebpv but the mechanic here stated that when the KAM is not working then the ECM has to relearn all the settings and that could cause the problem I'm having. Next step seems to be using a breakout box to check pinout #55 on the ECM. There is a local Italian place close by that is certified by FORD for maintenance. Guess I'm forced to try them. As long as she don't leave me stranded on the side of the road, or I'm not hurting her, I'm forced to keep driving until the issue is resolved.
Twawsi is offline
post #8 of 21 Old 11-11-2013, 12:33 AM
Rodslinger's B1TCH
mine was doing the same thing except I let it go until I had serious problems getting it started.
rotella t6 made it all go away. even at $20/quart it's going to be cheaper fix than a mechanic throwing parts and troubleshooting hours at it.
driving it the way it is isn't going to hurt it either.
steve604 is offline
post #9 of 21 Old 11-11-2013, 12:00 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
Is it diesel? I expect it is but making sure,
Its called being a cold diesel, mine has done this since new
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #10 of 21 Old 11-11-2013, 01:30 PM
CSIPSD's Avatar
I dont know the particulars of your motor, being over there... But here in the states they do not have a GPR, but a GPCM (Glow Plug Control Module)...
Did you check that?
My next thing would be to ask does it sound different when it does this?
Next is pictures? Is it right hand drive?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
