Will They Fit? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 07-24-2008, 01:27 PM
Send a message via AIM to jetskier2313
Will They Fit?
I have a 01 EX 4x4 that is stock. Will 33" BFG A/T tires mount on the stock rims and fit on the truck with out rubbing?
How much louder are these tires compaired to the firestone transforce tires?
How many miles can I expect to get out of the BFG tires? I do a lot of boal hauling! I drive alot of highway miles!
Will these hurt my MPG's at all?
Thanks
Old 07-24-2008, 01:31 PM
I dunno it might rub a lil when turned to bump Mine would rub on the back sid on the black plastic inside the wheel well
Old 07-24-2008, 01:33 PM
mileage will go down a tiny bit and they will gice u 15-20k if u keet ur front end aligned and rotate them often
Old 07-24-2008, 01:37 PM
wow serious only 20k? Wow
Old 07-24-2008, 01:48 PM
back to business
You should get alot more than 20,000 miles out of BFG AT's. I had 30,000 on my MT's when I sold the truck with a little less than 1/2 tread left (the MT's and a softer rubber than AT's)
And, the AT's are quite quiet, any additional noise over the firestones will be minimal.
Old 07-24-2008, 02:03 PM
I wish that there would be a way to try tires out before you buy them. I want to know if it rubs or not!! haha
Old 07-25-2008, 07:44 AM
Are you buying a tire that is SAE size or Metric? What is the exact size of the tire(s) you are looking at?
My Ex with 305/70-16 on 16x8 wheels with V fronts is ok but will rub on OEM mudflaps. My parents Ex with 285/75-16 on OEM 16x7 with V fronts is ok with OEM mudflaps.
