Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
  #11 (permalink)
Old 06-29-2008, 11:14 PM
RanchStroke RanchStroke is offline
EGT TEMPS
Are you guys running a converter still on the exhaust?
  #12 (permalink)
Old 06-30-2008, 05:38 AM
Maverick4x4 Maverick4x4 is offline
I don't believe mine has a converter....I've looked for it but didn't see one.
I'm going to see if I can fashion a leak detector tool like in the link Raul provided.
Brett
  #13 (permalink)
Old 07-01-2008, 07:42 PM
I put the leak detector where the filter goes, right? Pump up the whole intake system? Listen for possible leaks? (I swear I sent this same post last night)
  #14 (permalink)
Old 07-01-2008, 09:32 PM
I pumped it up to 5psi a few times and it bled down...but I have no idea where from...whether it was between the intake and the turbo, between the turbo and the intercooler, or between the intercooler and the cool side of the turbo. A squirt bottle of soapy water told me nothing.
  #15 (permalink)
Old 07-01-2008, 09:33 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
i would try to pump more air into the system and see if you can hear the leak more
  #16 (permalink)
Old 07-03-2008, 07:29 PM
Jordon Donald Jordon Donald is offline
Mavericks egt problem
Hey Maverick, sorry for the delay but to answer your question no i pulled my Cat Converter. The dealerships where i live flat out told guys to cut them off. who knows maybe yours is plugged with some major crap.plus we have no emission standards. as for checking about your boost leak. i'd hit it with more psi than that. think about what a turbo puts through it. the slit on my inter-cooler boot was like an inch and a half so it was easy to hear but the clamp hid it.
  #17 (permalink)
Old 07-05-2008, 03:14 PM
No cat on my truck.
I'm not concerned about the intercooler side of the turbo at higher pressures, it's the filter side of the turbo that makes me nervous above 5psi.
  #18 (permalink)
Old 07-05-2008, 08:00 PM
Soaggydogg Soaggydogg is offline
High egt's are probably from leaking CAC plumbing or the up-pipes.
Add to your signature what truck, year, model, mods..........
  #19 (permalink)
Old 07-05-2008, 11:37 PM
What is CAC?
  #20 (permalink)
Old 07-06-2008, 04:01 AM
06LariatF250 06LariatF250 is offline
Send a message via AIM to 06LariatF250
i actually have the same problem, on my hot tunes my egts get quite high i am running the ultra comp tune from spartan and my bost at wot is only like 22-24 but my egts are skyrocketing i have had this problem for a while, i already replaced a cracked up pipe, i dont know what to do and is really ticking me off
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
