brake controller no power - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 6 Old 09-29-2013, 05:10 PM Thread Starter
i popped a fuse under the dash on my 02 ex. heard it pop and now i have no power to the controller. the controller works in my other truck so its not a dead brake controller. pulled every fuse and none were blown. where does the controller get power from? google came up with nothing and my haynes manual and a chilton manual gave me nothing.
greasemykey is offline
post #2 of 6 Old 09-29-2013, 05:13 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Did you use an ohm meter to test the fuses? If not, you didn't check fuses. Looking at them means nothing.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 09-29-2013, 05:17 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
I popped the same one in my 2003 Excursion. There is definitely a dedicated fuse for the brake controller. It's one of those tall square ones under the dash. Maybe #101. Definitely 30A, because I was able to temporarily use my power seat fuse until I could get a replacement. (I do have the 6.0, but I'd imagine the fuse boxes are relatively the same.)
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #4 of 6 Old 09-29-2013, 05:20 PM Thread Starter
thanks ill check the #101 or at least all the square 30 amps
post #5 of 6 Old 09-29-2013, 05:52 PM Thread Starter
101 was the culprit. ill have to pick up a handful of those square fuses tomorrow. thanks for the help
post #6 of 6 Old 09-29-2013, 07:19 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
They're like $5 or $6 a piece at my local mom and pop auto store. Yikes!
ynpmoose is offline
