Best way to level (or small lift) Excursion - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 9 Old 09-28-2013, 11:51 AM Thread Starter
I'm looking for 3"-4" max. I think my curent springs are sagging so I think I would like to get new springs. My question is will any superduty springs fit and will they provide any lift. I have seen that there is different codes of springs?? Like an x code or v code I'm to sure what that refers to. I want to clear 35"s at the largest but may have to settle on 33"s if there is major clearence issues. Also I'm not to concerned about the ride quality I'm used to one ton trucks. Thanks in advance. Tony
rehahomes is offline
post #2 of 9 Old 09-30-2013, 04:41 PM Thread Starter
No imput? More less want to know if f250/f350 springs will fit and if they will provide any lift.
post #3 of 9 Old 09-30-2013, 04:55 PM
Raul@Stealth Automotive's Avatar
they should fit... if your springs are sagging and you get new springs then they will lift it slightly
Raul@Stealth Automotive is offline
post #4 of 9 Old 04-29-2014, 08:01 PM
heykw's Avatar
X springs sit about 2" lower than superduty springs in the front
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #5 of 9 Old 04-30-2014, 03:53 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Contact Cary at CT Performance. Super informative about Ex lifts. I bought my kit from him but I probably could have bought it a few hundred dollars cheaper by piecing it together on the internet. It was worth the extra money for tapping into his knowledge and and vast experience
384,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #6 of 9 Old 05-02-2014, 11:34 PM
heykw's Avatar
What size tires are you running?
heykw is offline
post #7 of 9 Old 05-03-2014, 03:25 PM
Christ Follower
Quoted: 14 Post(s)
They are factory 20" wheels/tires off of a 2010 F350. I think the tires are 265/75R20
384,000
PHP Hydra
MBRP 4" Turbo Back
Firestone Ride Rite
Derale Atomic Cool
post #8 of 9 Old 05-04-2014, 03:10 AM
Term3's Avatar
I've gotten lots of good Excursion suspension advice from Cary at CT Performance Inc. he specializes in Excursions.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #9 of 9 Old 05-04-2014, 03:34 AM
c dog's Avatar
I did F550 "X" code leaf springs with a 3" mini spring pack on the front. I did F250 leaf springs (did the B mod) and a 4" block in the rear. I am running 35x12.50x20 tires
c dog is offline
