Burnt rubber smell at start up - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 3 Old 09-13-2013, 11:21 AM Thread Starter
Just like the title says, I am occasionally getting a burnt rubber smell right at startup. It goes away almost immediately and it does not happen at any type of regular interval. I have looked throught the engine bay, nothing obvious. Anyone else had this or have a suggestion where to start with this? Thanks
macsdaddy is offline
post #2 of 3 Old 09-13-2013, 11:45 AM
6liter_BigSkyStroker's Avatar
Check your starter cables is where I would start. If it is smelly right after startup you possibly have a starter cable melting due to high resistance, heat during cranking because of high amp draw. Also check to see what your starter is pulling for amps. Maybe a weak worn starter.
2005 F250 SuperDuty, EGR Delete Kit, Head Studs, 4" MBRP Turbo Back Exhaust, Cat Gone, BATMOWHEEL, S&B Cold Air Intake System, 18" Wheels, Swamps 58V Hot FICM
, AND SCTX3 Tuner with 3 custom tunes! Thanks Eric at Innovative Diesel
6liter_BigSkyStroker is offline
post #3 of 3 Old 09-13-2013, 12:00 PM Thread Starter
Installed a new starter (at 150k seemed a good idea anyway) inspected all the wired to and from it, no issues. Still getting a burning smell right at start up. I did notice my spider and the cac inlet and outlet were pretty dirty on the surface, wondering if I have a leak that would put off the smell at startup.
