Transmission Flush - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 24 Old 08-20-2013, 05:30 PM Thread Starter
Transmission Flush
My buddy gets great deals on amsoil products so I bought transmission fluid for my 2000 X 7.3L w 218k miles and took it to my local diesel mechanic and they said I should not flush because it could shock the transmission. The transmission is original. Is there any truth to this?
Aclax8 is offline
post #2 of 24 Old 08-20-2013, 06:23 PM
Quoted: 859 Post(s)
Feedback Score: 3 reviews
Yes. Don't do it.
Funny but not so funny. I flushed mine with amsoil a month after I got my rig. Two weeks it was toast and I never pulled anything with it. I dropped the pan and all of the clutches were muck in the bottom.
But now I got a BTS
And yes, I put Amsoil back in it.
Corey@CNCFAB is offline
post #3 of 24 Old 08-21-2013, 03:35 AM
CSIPSD's Avatar
Your fine. You can swap the fluid without issue. Disconnect the supply line of the trans that goes to the cooler. Start the truck and drain out 3-4 qts, then add back, then do the same thing but at one time pull the truck thru reverse and drive and 1-2 to get all the fluid out.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 24 Old 08-21-2013, 04:11 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i would NOT flush it. the shop is correct.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 24 Old 08-21-2013, 06:52 AM
CSIPSD's Avatar
LOL... Ya, its always smart to NOT service your tranny... By doing proper service you will cause it to blow up...
Change the fluild, there is no such thing as a power flush anyway and there is no risk of damage by properly servicing the tranny.
4R100/E4OD Trans Flush Procedure - PowerStrokeNation : Ford Powerstroke Diesel Forum
Great write up on how to do it...
Joe
CSIPSD is offline
post #6 of 24 Old 08-21-2013, 07:47 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Ive heard two schools of thought on servicing trannys with 200,000+ that havent had a change before, which is true or truer? that if you replace all the fluid with new, the detergents in ATF washes the varnish off the clutches and causes it to eventually fail, but then ive also heard that if you only drop the pan then the new ATF cant bond correctly with the old fluid still in the converter and again eventually causes failure. Is either of that true, i have never messed with many auto trannys before but its getting about that time for me as well
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 24 Old 08-21-2013, 07:53 AM
Quoted: 859 Post(s)
This info is from Brian Thompson owner of BTS. Not word for word though if someone wants to be annoying.
Never flush the transmission. Just normal service of the filter and replace only what was removed from the pan and top off what is necessary.
Keep up on your normal maintenance schedules and you'll be golden.
post #8 of 24 Old 08-21-2013, 07:58 AM
CSIPSD's Avatar
And my info comes from the design engineer that designed, tested and worked for Ford...
Where in any of the info above does it say the tranny has never been serviced? Why is it that Ford recommends full tranny service every 30-50k?
Service your trans, no matter what the resident forum IDE (internet diesel expert) says to do...
Joe
CSIPSD is offline
post #9 of 24 Old 08-21-2013, 08:15 AM
Chapter Director
Quoted: 5 Post(s)
This isnt about any internet forum masters just some of us havent had the pleasure to have a truck that was as well maintained as it should and its a worry in a tranny that hasnt been serviced in its whole life, what the proper procedure is to maximize its life
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 24 Old 08-21-2013, 08:25 AM
Quoted: 859 Post(s)
Here we go again. Lol.
Your design engineer is the reason Brian and John Wood and other reputable shops are doing such excellent business.
