Buying a 2002 Excursion 7.3 Limited with 290K miles - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 4 Old 08-13-2013, 08:40 PM Thread Starter
So I wanted to get everyone thoughts on purchasing a one owner 2002 ford excursion 7.3 4x4 limited with 290k miles. It has been serviced at our local ford dealer it's entire life. They have all the service records from the beginning. washed and detailed once a week - was used to haul the kids around from birth to now. They bought it new at the ford place. I am going to look for the standard stuff - tranny, balljoints,UVC, injectors and blowby, turbo, etc. Anything else. They have it priced at 8k - interior is spotless according to conversation I had with the owner this evening. If no blowby or other major stuff when driving it - it may find a new home.
rdrx7 is offline
post #2 of 4 Old 08-14-2013, 08:00 AM
jetskier2313's Avatar
Send a message via AIM to jetskier2313
I would also check:
Water Pump Housing for leaks
If it still has the auto hubs in the front I would check to make sure that you are able manually lock them easily. (Meaning got to the hub and turn the dial to lock, if its not easy to turn there is a good chance they are bad)
I would check the leaf springs as well.
I have over 400k now on my EX and I had a front leaf spring snap on me around 330k. I got the heavier complicity ones now.
It sounds like a good find!
2001 Ford Excursion Limited
DIY Intake
Foil Delete
Headlight/Foglight mod
10k Mod
Gauges
Dual Fire/Ice Led Bar in the Rear
Led front
HID Projector Headlights and LED Fogs
TW 6pos Chip (Stock, Eco, tow, extreme, race, smoke) :burnout
2400watts of bass in the back
EBPV Manual switch!!!
455000 on the clock and counting
jetskier2313 is offline
post #3 of 4 Old 08-16-2013, 08:37 PM
whats the price ?
SUPRA180 is offline
post #4 of 4 Old 08-18-2013, 03:17 PM
That sounds like a good price if it checks out as described.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
