Tranny trouble - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 2 Old 07-26-2013, 11:26 AM Thread Starter
Unhappy Tranny trouble
I have a 2000 Ex limited with 185k miles. The transmission is jerking when it is in overdrive, but the rpm's do not rise. I am not sure if this is the tranny "slipping" since the revs don't increase when it happens. I am considering a replacement from Monster Transmissions. Does anyone have experience with this company or advice on a good quality replacement tranny? I would love to convert it to a 6 speed manual, but I don't think I have the cash for that.
mtnrider27 is offline
post #2 of 2 Old 08-22-2013, 08:19 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
1) I haven't seen anyone convert from Auto to manual, especially for a 4WD... but if it's 2wd - could be done I would think fairly easy.
2) when it starts to jerk - a) is it when it goes into overdrive? and b) is the Overdrive Off light on the shifter handle blinking? either way, i'd get a shop to scan the PCM to look for codes.
Also, if you push the O/D off button (solid light on) - when it shifts into 4th and stays - does it still jerk?
If not - then honestly - sounds like your overdrive clutches are burned up or, if I recall correctly - there's a drum that's been known to crack and do this as well.
Likely from someone not towing properly when in overdrive.
I don't think it's solenoids or valvebody just for the simple fact that it seems to be shifting (and down shifting) properly.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
