Disappointed in fuel mileage while towing - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 11 Old 07-25-2013, 06:21 AM Thread Starter
Tow vehicle:
2001 excursion 4wd, 285 bfg all terrain's, 4" magnaflow turbo back, AIS intake, PHP tunes.
Travel trailer is 28ft and roughly weighs 7500lbs loaded.
Do between 65 and 70 I averaged 8.2 mpg. On the return trip I did 75 and got 8mpg. I would think I should get atleast 10mpg doing 65 to 70. I sold a suburban because it got 8mpg. Granted the excursion pulls better, but I still expect better mpg. Where do I start? Or does the mpg sound right.
Thanks - Shaun
pickit is offline
post #2 of 11 Old 07-25-2013, 07:07 AM
timmyboy76's Avatar
got gauges? Check the firewall for soot stains. Build a boost leak detector. Is the Ex chipped?....
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 11 Old 07-25-2013, 07:29 AM Thread Starter
I have gauges. PHP tunes. I can build 25psi boost. I'm lost on what it might be. I'm going to check ebp and go from there I guess.
pickit is offline
post #4 of 11 Old 07-25-2013, 08:23 AM
Quoted: 17 Post(s)
Yeah something may not be right there. I get 13 towing 70 ish pulling my heavy *** jeep & trailer (guesstimate 9,000). You hand calc or overhead console?
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 11 Old 07-25-2013, 08:55 AM Thread Starter
Hand calculated. The excursion only has 118,000 miles on it. I am the second owner. It's been maintained well. The original owner used stanadyne for every gallon he said. It has a turbo temp monitor so the engine does not shut off until the turbo has cooled down. I need to find someone with a good scanner that can run some test and see how everything is operating. Thanks for the replies.
Thanks - Shaun
pickit is offline
post #6 of 11 Old 07-26-2013, 08:11 AM
timmyboy76's Avatar
if you plan on keeping the X for the longhaul...it be a good idea to have ur own..
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
post #7 of 11 Old 07-26-2013, 12:25 PM
How's the fuel mileage unloaded (not towing)?
Davenfla is offline
post #8 of 11 Old 08-07-2013, 02:59 PM Thread Starter
I just took a trip about 385 miles. I would say 70 percent highway 30 percent stop and go. I topped it off and hand calculated was 14.8mpg. Before the trip I cleaned the EBP tube, it was about 30 percent blocked. It took some work to get weedeater line through it. I have definitely noticed the accelerator pedal is more responsive. My wife even noticed the difference when she drove it. Any more suggestions before I find someone to hook up a good scan tool?
Thanks - Shaun
pickit is offline
post #9 of 11 Old 08-07-2013, 03:21 PM
That scan tool that Timmy linked is nice... I don't like being dependent on someone else when I have the means and the way-with-all to do it myself. To old to change now...
...just sayin'
Davenfla is offline
post #10 of 11 Old 08-18-2013, 06:50 PM
What are your egt's while towing? Those mileage numbers sound like me towing two jeeps across Nevada to Rubicon, when my egt's are pegged. I just pulled a 26' "parachute" (very tall enclosed trailer) to Wyoming and back, 8ish on the way there, 10 on the way back. With the heavier loads, I spend more time with OD locked out to keep the egt's lower. Towing one jeep, I get 10ish.
For reference, highway at 75ish is 15, around town is 11.
Brett
'02 X: V codes & add-a-leaves, bags, upgraded tranny, 295 Nitto's & 325 Duratracs, pyro & boost, BTM, Stage 2 CAI, DP 60 & 80 high altitude tow, 80 econ...smoke on demand.
Maverick4x4 is offline
