Poor highway MPG 2000 7.3 - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 7 Old 07-15-2013, 07:05 AM Thread Starter
I have a 2000 Excursion 4x4 with a 7.3. It has 295/60/20 Terra Grapplers on it and a Superchips programmer in the performance setting. Brand new air filter and oil change. I filled up and headed out on vacation and drove 602 miles before stopping for fuel again. When I stopped to fill up, it took 41.122 gal. So 602 miles divided by 41.122 gallons comes out to 14.64 MPG. Disappointing to say the least. Anyone have any ideas? Any folks in Myrtle Beach SC out there? Thanks in advance.
Rahn is offline
post #2 of 7 Old 07-17-2013, 07:20 AM
My Ex doesn't do very well at all, but I suspect that having a few inches of lift, Ranch Hand bumper, and 325/60-18 tires doesn't help. I am wondering about trying to clean up the front aerodynamics a bit. It might have some converter slip as that appears to be another source of decreased mileage.
AnotherStroker is offline
post #3 of 7 Old 07-17-2013, 09:34 AM Thread Starter
I did read that if your exhaust back pressure tube and switchis clogged it will cause poor mileage. I'll look into that possibility when I get back home. There are some good videos on YouTube about 7.3 MPG tips.
Rahn is offline
post #4 of 7 Old 07-18-2013, 07:20 AM
DieselManor's Avatar
That's about right for a stock truck with those mods. You might want a look at doing the In-tank" and "Pre-Pump" mods to remove any air getting into your fuel system. It's cheap and could increase your milage 1MPG or more.
David Murphy
DieselManor is offline
post #5 of 7 Old 07-26-2013, 06:40 PM
Carpenoctum's Avatar
Ebpv staying open?
Carpenoctum is offline
post #6 of 7 Old 07-28-2013, 11:31 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
Mine (01 4x4 285/75/16 tires, leveling kit) will only get great mileage at 68 mph or below, if you were driving 75mph I'd say your pretty close on mpg, if slower then you have a problem
ageekwithajeep is offline
post #7 of 7 Old 08-22-2013, 08:32 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
If your running the stock air box - Do the ZooDad mod.
Or upgrade to the 6637 air filter mod - you'll pick up 1 to 2 MPG alone from that (speaking from experience.)
After that - definitely check the EPBS tube/sensor and clean it.
I have not done the hutch/harpoon mods yet - but that's on my to-do list.
But I can say that with new filters, and oil changes and a clean tube - and no tuning - I was able to get 20mpg on the highway at 70mph on my last road trip (not using cruise control either) and I'm about the same tire size as you.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
