Voltage Problem - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 2 Old 07-09-2013, 02:40 PM Thread Starter
Voltage Problem
I am a Newbee. My 2000 7.3 Excursion has a problem. My dash gauge volt meter only reads 8 volts but the alternator and batteries are 13+ volts. Shop said I'm only getting 11 volts to the computer. I have been having trouble with the transmission not shifting properly -- it sometimes hunts. After I drive it for about an hour the dash gauge voltage comes up to the normal range. Just paid a shop to check iot and they redid 4 ground terminals and a new ground terminal on one of the batteries -- still same problem.
donverrico is offline
post #2 of 2 Old 07-09-2013, 05:29 PM
Did they load test the batteries? How are the battery terminals? When I bought mine the salesperson said "The theft light sometimes stays lit maybe a problem with the alarm". While checking under the hood one I pulled one of the terminals off, problem solved. Sounds like a loose connection somewhere.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
