Converting gas to diesel - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 6 Old 06-11-2013, 05:43 AM Thread Starter
There are tons of gas Excursions on the market, around here. Or, at least, a lot more gassers than diesels.
And 7.3 Powerstroke engines aren't hard to find, either.
Anyone know if it's even vaguely reasonable to be thinking about swapping-in a diesel engine? Other than the engine/transmission, what else would need to be swapped? Transfer case? Are the driveshafts the same length regardless of engine, or are they different?
BrownianHeatingTech is offline
post #2 of 6 Old 06-11-2013, 06:03 AM
Dont forget electronics
zillafreak is offline
post #3 of 6 Old 06-11-2013, 06:16 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Theres alot of work but it has been done before no doubt, id imagine its easier than a cummins swap since your going from the same maker rather than different ones
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 6 Old 06-11-2013, 08:03 AM
Quoted: 17 Post(s)
I thought about this before I bought mine, trouble is by the time you spend the money in doing so you could have found one for the same price or lower. This depending on what all you removed you could resale. You could look around for one even if its not local, for instance I broadened my search area in thoughts that I could drive down or get a cheap flight to the location. Persistence payed off in my case, I had been looking at X's since September (some sold right after I turned my credit app in) & my friend sold me his in March of this year (I paid cash)
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 6 Old 06-11-2013, 09:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If you can find a good parts truck like a roll over, take everything, dash and engine harness, your going to need a new fuel pump and pick up in the tank, which also has to be cleaned too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 6 Old 06-13-2013, 04:36 PM
chrgd2000's Avatar
I wouldn't do it. Just wait and keep searching. Found mine for $3500! Only needed an injector and the PO didnt want to deal with it. If it's far from you maybe you could get a member from that area to go look at it for you.
--7.3
chrgd2000 is offline
