Front bench seat? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 4 Old 06-09-2013, 03:00 PM Thread Starter
Front bench seat?
I really like the 40/20/40 bench seat in my F350. I've never seen an Excursion with that setup. I expect to haul a good bit of tools and cargo in the back portion, so even if I get one with the third row, I'd probably remove it, thus resulting in a five-passenger vehicle, which I find to be one too few in many cases (having three kids).
If I get a seat from an F350, is it a direct bolt-in swap with the Excursion front seat? Or will it require fabrication (which isn't necessarily a problem, but I want to know what I'm getting into)?
BrownianHeatingTech is offline
post #2 of 4 Old 06-09-2013, 03:21 PM
If I recall correctly when I was shopping for mine I saw one with a bench seat. It was an ex-government xlt with rubber floor mat as well.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
post #3 of 4 Old 06-09-2013, 04:31 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes it will bolt right in but you would have to get the whole set because the captains have the front armrests and would get in the way but good luck i think most guys want the jumpseat so they are like gold
Your thinking of the solid bench seat he is talking about the 40/20/40 flip up console seat. they are different i dont think excursions ever came with the flip up console but i could be wrong
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 4 Old 06-09-2013, 11:41 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Floor pan should be the same. Might have to drill some holes in the floor. Removing the arm rests is possible if you can live with the hole in the side of the seat's cover. There is a steel 'nub' that must be cut off to clear the middle seat back. Did this in my red trk... 5 kids, need every seat I can get!
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
