02 excursion metallic scrape sound on startup - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 6 Old 05-31-2013, 06:24 AM Thread Starter
Hi all. Bought my 02 excursion a couple months ago. In the last couple of days it's started having a metal rubbing on metal or high pitched rattle noise on startup. When I drive it about a hundred feet or so, it stops. If I turn it off and restart it, the noise is back until I drive it again. It never does it except on startup. Perfectly fine driving down the road. I'm wondering if the starter isn't pulling back in and my driving pops it in. It won't go away while revving at idle either. Anyone have anything similar happen to them?
logran is offline
post #2 of 6 Old 05-31-2013, 07:09 AM
Term3's Avatar
Quoted: 2 Post(s)
Check idler pulleys and also the belt drive for the water pump. There's not much clearance between that and the front cover and if its loose or bent it'll make contact. If it is making contact it won't be long before you have a coolant leak.
Oops just noticed the year of your truck, I was thinking 6.0
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 6 Old 05-31-2013, 07:32 AM Thread Starter
Yeah, I'm pretty sure it's in the starter circuit. I found a tab for it too. Still want opinions though
logran is offline
post #4 of 6 Old 06-04-2013, 10:47 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
i would say its the starter.
sounds like its not disengaging all the way
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #5 of 6 Old 07-14-2013, 06:20 AM
subeng's Avatar
Check your starter bolts, mine were backed way out and one was just about to fall out. Mine was doing the same kind of thing. I check them during every oil change now. More then likely your bolts have never been checked and are possibly backed out enough to cause your issues.
subeng is offline
post #6 of 6 Old 07-14-2013, 06:58 AM
STANGMAN893's Avatar
I agree with the starter thing. Mine fell out once. Caught it before it did it a second time. heard loose exhaust clamps doing that too.
STANGMAN893 is offline
