2005 steering wheel on a 2000 excursion 7.3 - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 10 Old 05-10-2013, 04:53 PM Thread Starter
Hello , I am a newbie to this forum. I purchased a 2000 Ex that had a 2005
steering wheel installed. I have button lights and horn, no warning lights. I Know I can't get radio buttons working ( radio also changed)
The cruise controls are hooked up but not functioning. Previous owner said CC worked prior to swap, but lives in NYC so had little need. All his other upgrades appear to have been done correctly. Has anyone done this swap an no what might be wrong. Do I need to put in a 2005 clockspring? Wiring under the air bag seems right, but since I do not have a color coded wiring diagram of the wiring assemblies, I can't be sure.:
painterX is offline
post #2 of 10 Old 05-11-2013, 04:22 PM
the swap is pretty well documented. a quick search here and or on the ford truck enthusiast forum will turn up a couple different threads on the subject. here is the best one I have found.
http://www.ford-trucks.com/forums/10...xs-how-to.html
SM
by
, on Flickr
2000 Excursion Limited 4x4
heated and power everything
7.3 ltr auto
f250 "V" code front and "B" code rear springs
KYB shocks
billet grill
aftermarket headlights
beans chip with;
1: stock
2: high idle
3: economy
4: tow
5: exhaust brake
6: no start
Big Boost
Ford Powerstroke severe duty air intake AIS
WWII
Sticker Monster is offline
post #3 of 10 Old 05-14-2013, 08:57 AM Thread Starter
Thanks Sticker Monster,
I really appreciate the reply.
I read the article on the swap. I am now just wanting to know if I need a 2005
clock-spring since my wheel is from a 2005 EX and previous owner says he did
not change the clock-spring.
2000 EX 7.3 ltr
ATS 5 star torque convertor
ATS Tranny Auto
Edge tuner
Harley headlights
2005 grill/bumper
Big Boost
Upgraded turbo wheel
2008 folding mirrors
rear camera
4" MBRP Exhaust
Bilstiens
painterX is offline
post #4 of 10 Old 05-14-2013, 05:31 PM
a clockspring from a 99 and up navigator or expedition that had the controls on the wheel or I believe 2003 and up excursion that had the audio and hvac on the wheel. all of those should work.
SM
by
, on Flickr
7.3 ltr auto
KYB shocks
billet grill
beans chip with;
1: stock
2: high idle
3: economy
4: tow
5: exhaust brake
6: no start
Big Boost
WWII
post #5 of 10 Old 05-28-2013, 10:37 PM Thread Starter
cruise button voltages
When the EX is on a scanner, it shows that the "on" button is only producing 4 volts. It needs 12 to turn cruise on. When 12v is "jumped" down at the connector under the steering column, it shows that it is turning cruise on, shows on the scanner screen. If I drive down the road and jump that same connection at speed, cruise does not engage. OK, maybe buttons are dirty/corroded, something. I got another wheel that owner guaranteed buttons worked b4 removing and that he just changed to go back to tan color.
I took those cruise button assembly and installed, still no cruise. All buttons on the scanner are functuioning but maybe the resistence is not exact and that is why cruise not working. Does anyone know if the resistance numbers on the 2000 cruise buttons and on the 2005 cruise buttons is the same?
Manuals do not seem to give that info. I also have two extra wires brown and a white, this is on the radio control side and I am assuming it is for the radio controls.
Thanks in advance,
Scott
painterX is offline
post #6 of 10 Old 05-28-2013, 10:41 PM Thread Starter
Sticker Monster, Just to be correct, are you saying that I DO need to change clockspring to one that had both cruise and radio controls, say, off of a 2005?
My clockspring appears to function since I am getting voltage from all the buttons, though maybe not the RIGHT voltage( as in the on button)
PainterX
painterX is offline
post #7 of 10 Old 08-28-2013, 06:23 PM
painterx
Did you ever get this figured out?
skatedoktor is offline
post #8 of 10 Old 08-29-2013, 11:55 AM
f350powerstroke's Avatar
the steering wheel on my ex is beat to shyt, wouldnt mind a 08+ superduty wheel
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #9 of 10 Old 09-01-2013, 06:47 PM Thread Starter
Cruise fixed
Hi Guys, Yes I did get the cruise working. I found a 2000 black leather wheel,
put in on,. hooked it up and all is good. Now I have (2) 2005 black steering wheels that are on no use to me. With the 2005 wheel and a scanner I never got the cruise engaged light on as it does with the 2000 wheel. Let me know if anyone wants my 2005 wheels?
PainterX out.
painterX is offline
post #10 of 10 Old 09-02-2013, 07:08 AM
alaskan155's Avatar
Quoted: 60 Post(s)
don't think the 08s will work, i think someone was saying the newer trucks use a hex instead of splines like the previous gens,
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
