Airbags & Turn Signal - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 02-16-2008, 07:40 PM
I need to replace the turn signal switch in the column. How do you remove the steering wheel with the airbags in them. Will it go off. Any help is appreciated.
2000 Excursion
7.3 liter 4x4
Old 02-16-2008, 07:42 PM
Rob Rob is offline
you should be able to remove part of the column cover to access it
Old 03-08-2008, 06:50 PM
I've replaced my turn signal 3 times now without removing the air bag or the steering wheel. How ever just to be safe I have disconnected the batteries for 5 to 10 minutes before starting.
Old 03-08-2008, 08:17 PM
Did you remove the steering wheel?
Old 03-12-2008, 04:21 AM
No need to remove the steering wheel, the plastic housing around the turn signal unscrews from underneath, also you need to unscrew the lever for the tilt. Just be careful at removing the cover around the flasher button. Once thats off you have two bolts to remove torqs head I believe then the wiring harness. Takes me about 15 to 20 minutes now to switch out.
