gpcm - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 6 Old 04-17-2013, 08:18 PM Thread Starter
gpcm
So I am getting codes for glowplugs 2,4,6,8. Thinking glowplug control module. Can it go half bad? Not hard starting, sometimes it cranks a little long, but don't want to just throw parts at it without testing first. Any ideas?
diggerfan99 is offline
post #2 of 6 Old 04-18-2013, 05:47 PM
RAMKILLER97's Avatar
Yes, mine went half bad. My whole passenger bank went bad but only 2 on my drivers side threw codes. Depending on how cold it is where you are, you may not really experience hard starting, especially if the other side is warming up properly. Anyway, your first step would be to pull the plugs off the gpcm and look and them and see if anything is obvious. Mine was burnt up on the side leading to the passenger side, causing that whole side to go bad. But if you are unable to tell you should pull your valve covers and check continuity through the valve cover gasket. This is the other thing that can through you a whole bank. While you are under there you should change your plugs anyway, you will be kicking yourself if you don't later on down the road, but if continuity is good leading to each plug, all the plugs you pulled look decent, you know that you have yourself a bad gpcm. I picked one up from ford for 150 I believe. And its way easier to change than the plugs haha.
Oh, and as a tip, when and if you pull of the passenger side valve cover, the one bolt in the far back corner, don't use swivels. I found that a 1/4 drive ratched and a short extention works way easier and is just enough room. Just some advice to save you my same frustrations
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
post #3 of 6 Old 04-18-2013, 06:08 PM Thread Starter
Thanks for the info, so when you say check continuity through the valve cover gaskets, I need to take the covers off? Never had them off before, had a cummins before this truck so, I am guessing it is like a 2 piece cover?
post #4 of 6 Old 04-19-2013, 06:27 PM
The valve cover gaskets are more than just a gasket, because ford can't do anything easy. They have a plug that runs through them and supplies power to the GPs. It clips on the outside of the cover and the inside. If you pull off the cover you can unplug them and get a multimeter that can send a charge through one pin and be able to pick it back up through the other pin. You have to look inside there and you can see where they run to and put the one pin on one side and the other on the on the corresponding GP and see if you have continuity. If you have power running through, you know that your valve cover gasket is good. Also you can check your GPCM from there. I you have a buddy it will be much easier, but you can turn your truck to the on position, better if the engine is cold, and see if you have 12v running to the gasket. If its some weird number, I think mine was like 8v you know you aren't being supplied enough power to properly hear your GPs so your GPCM is bad.
Hope that didn't come off to confusing haha, electronics are not my thing, I had my dad do this part while I just took it all apart and put it back together.
post #5 of 6 Old 04-20-2013, 07:41 PM Thread Starter
Went ahead and replaced GPCM and check engine light is now gone. Has not come back so I think it is solved, thanks for the help.
post #6 of 6 Old 04-20-2013, 07:46 PM
Glad to here you got it fixed.
