Will 33's fit on a stock height ex? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 02-04-2008, 06:39 AM
I am considering dropping down to 33's from 35's and 8" lift. Can I go to stock and fit 33 or do I need a small lift?
thks.
D
2001 ex 4x4 diesel
Old 02-04-2008, 11:27 AM
My 275/70/R18's figure to be 33" tall and I'm on a stock lift with no rubbing.
Old 02-10-2008, 08:21 AM
4"
If you take it off road and torq it at all 33's with stock suspension will rub especially a knoby or wide set of 33"s they will almost surely rub so if you are going with a mud tire or anything with any width a 4" up front 2" in the rear lift will keep you from rubbing even if you get'r crossed up wheel'n every now and then.
Old 02-10-2008, 08:29 AM
i ran 33s all-terrians on stock with some rubbing but nothing real bad except for the turn radius is horrible.
Old 02-10-2008, 09:17 AM
my nitto's measure 33.25 and dont even come close to rubbing all depends on what wheel you put it on back spacing is key
Old 02-10-2008, 09:20 AM
Backspacing and side lugs on the tires are the most critical.......33's can rub but if the truck is set up with the right wheel/tire combo they wont...
Old 02-15-2008, 05:18 PM
I ran both 295/75/16 BFG all terrains on both the X and SRW with no rubbing.
Unless the rim is really offset a 33 shouldn't rub. Right now the X has 265 Ravo's and when they were new they rubbed a little. The rims are Centerlines and have more of an offset than the American Racing.
Old 02-15-2008, 06:06 PM
I run the same tire as dougger222 on stock rims. No problems at all.
Old 02-15-2008, 06:44 PM
Well I am running some 50 series low profile Toyo mudders/33's on some 20's and I had the shop set me up on the stock height first and they rubbed! I wanted 24's (rims) but if you are going to tow anything and want to stick with a mudder your limited to tires that are thin walled/not rated for towing(very few plies maybe 1 or none with steel belting) and then you take the risk of trashing your tires and rims towing anything with size or weight to it.
Most shops can tell you if the tire will rub on stock just by looking it up on their computer.
Old 02-17-2008, 10:35 AM
I have 305/70/16 BFG AllTerrain's on stock suspension, mounted to MickyThompson classics. No rub and plenty of room left over. Will be switching to 315/75/16 Shortly. It's an 02 ex
