I can smell Diesel Fuel - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 01-12-2008, 12:11 AM
I've not looked under the hood yet, as it's been so stinking cold, but I'm pretty dang sure I can smell diesel fuel from the engine area? Is that normal or might I have a leak somewhere?
Also, if that's not normal and I do have a leak, what are the most likely places to start looking? Fuel Filter I'm guessing, but since I've only had the truck for 2 weeks, and it's my first diesel, I'm pretty clueless, so any tips are welcomed and appreciated.
Old 01-12-2008, 12:13 AM
im fat and ugly
when did the smell start?
Old 01-12-2008, 01:49 AM
Its probably coming from the back of the fuel filter. The o-rings on the fuel filter drain pet**** could be your problem.I had the same problem on my 99 .$3.00 fixed my problem. Search the other posts under fuel leak.There have been several posts with this problem. Hope this leads you in the right direction.
Old 01-12-2008, 04:39 PM
crashfirefighter has both the best answer and the best price. Heck, I paid $5 for those rings....but they fixed that smell pronto.
Old 01-12-2008, 07:00 PM
Not sure, I think it's always been that way. I just never noticed it -- but I've only owned it for about 2 weeks so...
Thank you, I'll take a look as soon as I can and see if that's the issue. I'll also do a search for fuel leaks in the forums.
Very good to know.
Old 01-12-2008, 07:07 PM
Desert Shield/Storm Vet
Might be this Separator Valve Rebuild
Old 01-12-2008, 07:21 PM
Rice Hunter
My best guess was listed. GOTTA POP THAT HOOD!!! Leaving that old O Ring on filter change is common mistake when changing that fuel filter. Two may be found!! Gotta Lookie First....................
Old 01-12-2008, 07:50 PM
ha ha, so what you are saying is that I NEED to get cold. All this postulation won't do me much good until I get a little cold, and dirty mmm, I do enjoy a little dirty
Thanks for the link, as that really helps. I'll have a look on Monday as it's supposed to get up to 35 degree's which is ... doable
Thanks again for the help. I did the search for fuel leak as well, and it seems that this is pretty common. At least now I know where to start looking.
