| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Lights in the dash
Hello guys, curious if you can help me out. I jumped in the truck early this morning while still dark, and I noticed a light flashing behind the gauge cluster behind the trim. (the the bulb is pulled, and in the dash somewhere) So someone has been in my dash before I bought it, I'm just curious what Lights are on the dash when starting that I am not seeing. Sorry, hard to give more info without taking the dash apart.
D |
What lights do you see when you start it? That may help narrow it down.
I'll have to look when I get home tonight.
i bet it is the THEFT light.
No, I see theft light
well there goes my guess
When I turn the key to the "on" position I have starting in the lower left corner, seat belt, batt, yellow air bag light, yellow water in fuel light, oil temp light, low fuel, now to the right side I have theft, abs, wait to start, SES and e-brake lights. What am I missing? AFter I start it also shows low range and 4x4 then they go out. I don't know what else there could be.
dash is easy to pull on these pull it out and look , you didnt mention the airfilter restriction light though that should be on when you first turn the key
Do you see the yellow engine light?
