| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Will these rub
The end of the week Ill be putting on my 20x10 ultra bolts with toyos AT2 305/50/20 on my stock height 2001 excursion 4x4. Will these rub whats your take thanks
I just put a 305/55/20'' All-Terrain on mine and it doesn't rub. I am stock height 4x4
Do your homework on offset/backspacing. No one can tell you if they will rub or not, without one of those two things.
Re: Will these rub
Max tire size for our trucks are 33's without lift kits. To determine tire size, here is what you do.
305/50/20. 305 is you tire width in mm. 50 is aspect ratio. Which you take 305(width) times aspect ratio as a % (.50) will give you side wall height of 152.5mm. Convert mm to inches by dividing by 25.4, which is how many mm's in one inch. Gives you 6", times 2 for 12" of upper and lower side wall height + the wheel diameter. 32". This is also assuming your wheels are the same offset as factory or a negative offset. Which means they stick out. Hope it helps. ![]() 305×.50=152.5 152.5÷25.4=6.0039 6.0039×2=12.0078 12.0078+20=32.0078 Sent from AutoGuide.com Free App |
