GPM - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 11-26-2007, 08:03 AM
GPM
Does any onr know how to check a Glow Plug Module ? I get a P0683 and P1249 codes. This beast is hard to start on cold days, but all the glow plugs are new and the harness checks out OK. So, any help on how to check the GPM ?
On the P1249, wastegate, I checked the lines, they are all ok. When I turn the key on the sensor that the lines go to from the wastegate click repidly, any thoughts ?
Old 11-26-2007, 08:27 AM
Powerstroke Techie
Are you talking about checking the glow plug relay? If so it is easy to check with a meter, just make sure there is about 12v to ground on the two big terminals when you turn the key on and no more than 1/2v between them.
Old 11-26-2007, 08:29 AM
GPM
Thanks,
On the Excursion they did not put a glow plug relay on them, they put a glow plug module. Must be a better idea, Yeah right.
Old 11-26-2007, 01:24 PM
Send a message via ICQ to RedneckGirl Send a message via Yahoo to RedneckGirl
I thought only the California emissions trucks and Excursions had the GPM....
Old 11-26-2007, 01:27 PM
X
This is an Excursion. You would think that there would be a way to test a GPM other than throwing a new part at it.
Old 11-26-2007, 01:36 PM
I understand it is an Excursion My question is do all Excursions have a GPM or just those set with the California emissions?
Old 11-26-2007, 01:40 PM
x
Great question, I am not sure. Does your have the GPR or GPM? Is it older than mine, (2000). I do know it sucks not knowing how to check one. Nice X by the way !
Old 11-26-2007, 01:46 PM
I believe mine has the relay...I have been trying to get straight answer from researching online-but no luck there. I am hoping I won't have a reason to figure out which is in there Maybe I'll figure it out when I'm changing glowplugs!
Mine is an '03...the sucker seems to have a TON of relays!
Thanks for the Ex love!
Old 11-26-2007, 01:49 PM
I bet yours has the GPM, I don't see Ford decreasing on how complicated these things can be. Look where the GPR is supposed to be and I bet you will see a piece of aluminum about 3 inches long with two plugs coming out of it. That is the GPM
Old 11-26-2007, 01:52 PM
If it were warmer and I was more ambitious I'd be right out there
I'll definitely be checking it out!
