| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
I have an 01 7.3 Limited Excursion with auto trans 195K. The shift detents are sloppy and I want to know can I reset them or adjust them to tighten them up. I am new to the forum please help.
There 2 things you can do that are easy, but remember, FORD has Never done a good job with the shift selector. They've been sloppy since the '60s
![]() First, look up above the brake pedal for where the shift tube transitions to the cable that goes to the trans. That "L" bracket is held to the tube with 2 torx bolts that come loose all the time. See if tightening them doesn't solve most of the slop (next is shift tube bushing and that's a lot bigger deal) Next, the red "pointer" is controlled by a string that's attached to the shifter, up underneath, that has a slotted metal tab at the end. You can't remove slop here but at least make the pointer aligned with the trans... |
Thanks I will let you know if it fixes the issue...
