| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
the transformation has begun
working on removing all the tan and gold on the exterior. new headlights are in the works too. it took me 4 hours to remove and clean up the passenger side. now i have to do the drivers side. i have some f250 v-code springs coming. it is also getting new ball joints, sway bar links and brake pads all the way around.
![]() 2000 ex by bmonkey36, on Flickr ![]() there by bmonkey36, on Flickr ![]() passenger profile 2 by bmonkey36, on Flickr now i have to find some black running boards. SM Last edited by Sticker Monster; 01-16-2013 at 02:17 PM. |
What all was involved? I've heard that all that holds on the side cladding is double sided tape, is this true? How's the paint fade, is it noticable where you took off the cladding? I'd like to take ours off, but the wife just wants me to paint it black, we don't care for the tan eaither.
there are some plastic rivets and a couple screws also.
![]() front fender by bmonkey36, on Flickr ![]() rear fender by bmonkey36, on Flickr ![]() rear quarter panel by bmonkey36, on Flickr i used a razor knife to romove most of the plastic rivets. they don't hold anything but the trim. the heads pop off pretty easy. the screws go back in to hold the fender liner. ![]() razor knife by bmonkey36, on Flickr i used a plastic pry tool to lift the edge of the panels and pulled them off with my hands. they came off quite easily. the door panels seemed to come off easier from the bottom up. ![]() plastic pry tool by bmonkey36, on Flickr ![]() front fender removed by bmonkey36, on Flickr ![]() all trim removed by bmonkey36, on Flickr after 12 years, with just a wash i don't see any noticeable paint fade. there is some light rash or what appears to be scale buildup around some areas of the edges of the trim panels. it's amazing how nice the paint looks, considering how much dirt and sand was under the panels. i think a wet sand with 1500 grit and a buff out will clean up 99% of the remaining marks. ![]() rash by bmonkey36, on Flickr ![]() scale buildup by bmonkey36, on Flickr ![]() scale buildup 2 by bmonkey36, on Flickr ![]() dirt accumulation 1 by bmonkey36, on Flickr ![]() quarter panel dirt by bmonkey36, on Flickr i have to order up some xlt stone guards for the quarter panel to cover these holes. i think i will get the mud guards for the front and back too. ![]() quarter panel holes by bmonkey36, on Flickr link to parts online 2000 FORD EXCURSION Parts - Ford Parts Direct Online: Buy Genuine Ford OEM Auto Parts & Aftermarket Accessories, Wholesale Prices ![]() xlt trim 2 by bmonkey36, on Flickr here is what it looks like after just a wash. i will detail the wet sand and buff in a future post. ![]() all cleaned up by bmonkey36, on Flickr SM Last edited by Sticker Monster; 10-29-2012 at 09:11 AM. |
Exellent documentation, you're a good man Charlie Brown! Thanks for taking the time to not only take the pictures, but edit/label them as well... Good Show!
I knew about needing the stone guards, others have talked about just welding/filling the holes, as a repaint was in the works as well... myself, I'd get the stone guards. Guess I'll keep hoping to get to strip ours... |
i am going to try some clr (calcium, lime and rust) cleaner before the wet sand to see what happens.
SM Last edited by Sticker Monster; 11-24-2012 at 06:07 AM. |
using clr undiluted seems to clean most of the white scale off, meaning a light buff and It should look great.
SM |
just to update this thread. I finally found some black running boards that didn't break the bank.
![]() running boarsd by bmonkey36, on Flickr I removed them from the frames and hosed off all the mud... ![]() new running boards by bmonkey36, on Flickr then I removed the existing tan covers and hosed off the mud that accumulates under the covers... ![]() mud by bmonkey36, on Flickr ![]() mud 2 by bmonkey36, on Flickr ![]() no mud by bmonkey36, on Flickr just a few short hours and oh what a difference!... ![]() all done by bmonkey36, on Flickr SM |
