00 excursion ac problem - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 07-25-2012, 08:11 PM
I have a 2000 excursion limited with the 7.3 the problem is the front ac only blows cool air I would guess about 70 degrees but the rear air will freeze you out of the back seats Any ideals on what to do or try thought about putting valves on heater core lines to be able to shut the core down like my peterbilt has would this help any or is it the mix door under dash not fully closing
Thank you for your time.
Old 07-26-2012, 08:05 PM
Sounds like the mix door, a known problem on fords. It's a rather stupid design if you ask me. If that is your case, a heater core bypass would allow you to have cold blowing AC. However, if your mixing door isn't closed all the way, you still won't be able to achieve the system's maximum cooling output. It is probably cheaper and easier than fixing the mixing door, but I would still recommend fixing it.
Based on my understanding of how this system works, if your mixing door is stuck, in the winter you won't get as much heat either. You are obviously getting air going across the evaporator coil. Let's just say 50%. That's 50% of the air that won't be going across the heater core. However, it is possible your mixing door isn't stuck, but it just can't close all the way. In which case, you will be able to divert all the air across your heater core.
Here is a link to a heater core bypass kit.
http://www.dieselsite.com/maxacassis...4-200373l.aspx
