| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Major 7.3 Problems. Advice?
About a month ago I bought a 2000 Excursion Limited 4x4 with the 7.3l. Went and test drove it, it drove fine, but over the last week or so, it has been hesitating when Im under steady acceleration. The rpm goes down a hair then back up then down a hair then back up vey quickly.The vehicle also feels like it jolts foward every few seconds when I have my foot on the gas. I figured it wouldnt be that big of a deal since it was a low mile truck (only 85k miles), and just thought it might be a dirty or bad injector or something.
I dropped it off at the local Ford Dealership my Uncle works at, and they called today saying that the turbo impeller is breaking apart and might be shooting shards of metal into the engine. Best case, they said I need a new turbo, and worst case, I need a whole new engine. This seriously blows, as its a 12 year old truck, bought from a mom and pop place as-is, so Im not sure what to do. Has anyone else ever heard of this? Especially on a low mile truck? It figures that I buy the 7.3 because everyone says it is bulletproof, then it takes a crap on me a month after purchase. Best case, what sort of turbo should I shoot for? Anything that will give good power/reliability in a daily driver without costing an assload of cash? Worst case, what should I do for the engine? Refurbished one? Crate engine? Im not sure what would be the best bet that wouldnt be that ridiculous in price, but still be a good engine to last for a long time in a daily driver setting.
What kind of intake is on it?
Read through the sticky's in the 7.3 sections and you'll get most of your answers. If you do need a new engine, it's better you understand what you're about to get into. A new engine will not be cheap. Look for a member named airfish. He can help in that aspect. If you just need another turbo, members sell em here all the time when they change things up. Another stocker might suit you just fine. 7.3's are tanks.........if properly taken care of and properly modded. |
The intake is a stock type of cone, but without the airbox around it. Looks to be somewhere sort of in between OEM and aftermarket. The only other mod it has is a 4" MBRP exhaust.
I figured the truck was well cared for, as all aesthetic mods were done right, and the truck was very clean inside and out. Thought it would be logic that if the previous owner took care of it on the outside and spent all this money on a big lift/shaved tail lights/wheels/tires/exhaust/kept the inside super clean, they would have cared for the engine the same way. Im guessing that a new engine would be around $5-6k plus labor? |
If that intake is what I'm picturing it to be, then that's where the problems starts and it most likely ruined your engine. Id immediately change it out for a Tymar (6637). you can make a DIY 6637 intake system for around $50.
You're in the right price range for a new engine. Though airfish could find you something cheaper. It all depends on how decked out of an engine you really want. Basically if you have any future power goals for it. The sticky's will explain it better than I am. Where are you located? Last edited by Skew12; 07-11-2012 at 09:22 AM. |
If you do have to replace the engine then go ahead and put all the right parts on the first time. Bolts/studs/springs/injectors/turbo/etc....sped a few hours on here lookin at builds and do what you want to do with it once.
Honestly, I would take the vehicle elsewhere to have it looked at. To me, that troubleshooting conclusion sounds dubious, at best. Whats breaking apart? The compressor wheel? I'd be amazed if it shot metal thru the intercooler and piping all the way to the intake plenums. The turbine wheel? The engine exhaust pressure would blow all that out the exhaust, not back into itself. Do yourself a favor and have it looked at elswhere. If the turbo is coming apart, a replacement isn't all that bad. Hell, with the symptoms you described, you could just have the CPS going bad. |
Sent from my DROID BIONIC while wasting time at work... |
That's sort of what I figured, so I have an appointment at a place today to take it somewhere else after I pick it up from the dealership.
I'll have to do that intake mod anyway, just to be safe. Let's hope this place comes up with a different, better diagnostic. |
