Transmission Temperature Gauge? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 10-01-2007, 06:35 PM
Anyone have advice on installing a transmission temp gauge on a 2000 Excursion PSD -- I am planning on also adding a fanned cooled aux cooler from BD. Can I tap the temp sender into the supply lines?
Old 10-01-2007, 06:38 PM
Desert Shield/Storm Vet
There is a service port on the side of the trans you can install the probe. Its quick and easy. I will look for a pic for you.
Old 10-01-2007, 06:39 PM
3-Gauge Install Pictures
Old 10-01-2007, 07:13 PM
thanks
Thanks -- got it seems easy. Appreciate the help.
Old 10-01-2007, 07:14 PM
You bet
Old 10-01-2007, 08:21 PM
Smile trans
can you have to low a temp on transmission fluid???
Old 10-02-2007, 02:00 PM
Sure I suppose. I don't know what that would be but everything has an operating temp and being to cold isn't good either. You probobly would get leaky seals if it was too cold. Normal temps for an automatic is 60-80 degrees over ambient temps without pulling a load.
Old 10-02-2007, 02:42 PM
That is not a good place to put a sending unit. The smooth part of your sending unit may be larger than the bottom of the hole. When you tighten the unit up, the bottom locks down and then breaks off. Now you have a broken sending unit and a leak that may cost you 2 to 3 hundred dollars to fix. This problem has already been posted.
