Just got Modded B code, X code leafs - still wanders - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 2 Old 05-14-2012, 04:52 PM Thread Starter
Got my Ex back from the shop, and on the drive home noted that it is a bit better, but still wanders too much. Not as much 'rolling pig' behavior on turns though.
Next stop is to check/adjust/replace the steering box, new shocks, and sway bar, along with alignment/tie rods/ball joints check/adjust.
Am going to reserve judgement on the spring swap until I sort out all other aspects of the suspension.
Was hoping for a WOW factor - drat!
At least by the end (of my wallet) I'll have a tight Ex-Box!
Flinch
Flinch is offline
post #2 of 2 Old 05-15-2012, 06:02 AM
Term3's Avatar
I would contact Cary for expert Excursion help.
ctperformanceinc@yahoo.com
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
