My 01 X Nightmare repair and Future Mods - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 82 Old 05-11-2012, 07:09 AM Thread Starter
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
Well I have a 01 X I've had since 1-08 And was My wifes to replace here suburaban but she wanted a 7.3 like the one I had in my truck. Well now my wife has here mustang and drives my 6.4 ford in the winter so this has kind of bacame mine. Well When I got it it had 156,000 miles now 214,000. I realy haven't done alot to it. The few things did was resealed the winshield it leaked, New front leaf springs, front wheel bearings, The front trans pump bushing (snow plowing), the front wheel joints, And many front brake pads. Furure plans It needs GP, new exahast, maybe injectors, air intake, front springs maybe (x), rear air bags, and any thing i might come up with. I don't have to may pic of it. But a few I do have and a few working.
Brings me to where I'm at now I am rebilding the brake system. Front and rear Calpers With brackets, front and rear rotors, front and rear pads. And add in driver's side upper and lower ball joints, and drivers side wheel joint. Here some pic's
Had to go buy damaged bolt kit just to get the dam locking lug nuts off
do we see a problem here??????
Then tore the kuckle down to change ball joints
All the new parts OUCH!!!!!
I got a set of stock rims for it with the wrong center caps but we'll see if they work
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
post #2 of 82 Old 05-11-2012, 10:54 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
Holy hell dude. That's one bugger'd up mess!
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #3 of 82 Old 05-11-2012, 11:12 AM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Yep but It will be right in alittle bit.
JJ
post #4 of 82 Old 05-11-2012, 07:50 PM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Well I got some work done to day
Changed ball Joints
Changed U joint
Forgot to take pic befor I put back together
Got the kuckle put back together
And got most of the brakes back together
Still Have to hook up lines and finsh driver's side front
JJ
post #5 of 82 Old 05-12-2012, 12:14 PM
Matthew82's Avatar
Had to do all that when I bought mine before I could even drive it, so yea I know how much of a PITA it is to do...as it is right now my hub bearings on the DR side of mine are shot and have the hub nut heat welded to the axle shaft so my axle turns ALL the time in 2wd
Originally Posted by fordmandan87 View Post
Matt are you on the sauce?
All 3 at the same time? Who do you think you are, Charlie Sheen
Matt the odds of you convincing the guy he's not in possession of a kryptonite vagina that commands top dollar for the hour is lower than me getting to bang a millionaire midget on mars during a meteor storm
Matthew82 is offline
post #6 of 82 Old 05-12-2012, 12:17 PM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Wow that's not good.
JJ
post #7 of 82 Old 05-12-2012, 12:24 PM
Matthew82's Avatar
Yea but it's life
post #8 of 82 Old 05-12-2012, 12:33 PM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Originally Posted by Matthew82 View Post
Yea but it's life
Yes it is I've been limping this with butting pads on it for the last 2 years and it was just time.
JJ
post #9 of 82 Old 05-12-2012, 12:50 PM
Matthew82's Avatar
heard that
post #10 of 82 Old 05-16-2012, 09:14 PM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Well got some work done on the X to day. All the calpers are on with lines hooked up but today i noticed the rear slides didn't have boots so they will bee in tomorrow so i can finsh it. also changed tires around will ake pic tomorrow.
JJ
