| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Wont start theft light flashing
Pulled n to get some coffee when I came back out truck wouldn't start tried several times then noticed theft light flashing n dash. Any ideas
The anti-theft kicked in. Mine did it a few months ago and It had something to do with my Superchip. I had to return mine to stock and then re-install the program. Do you have any chips/programmers installed?
It has something to do with the PATS system installed which reads a code from the key. Do you have a second key you can try? If not, Try this. It works for me: THEFT LIGHT (on Excursions) - If the theft light flashes rapidly after programming and the vehicle won't start, the Passive Anti-theft system (PATS) will need to be reset. To reset the PATS, perform the following steps: 1. Turn the key on, but do not attempt to start the vehicle. 2. Wait for the theft light to quit flashing rapidly. This should take about 45 seconds, after which the THEFT light will flash multiple times about every 3 seconds. 3. Turn the key off and remove the key from the ignition for 30 seconds. 4. Insert the key and turn the ignition to the ON position. 5. The THEFT light should illuminate for about 5 seconds and then go out. 6. Continue to start the vehicle normally. Hope this helps....works for my 03 X. |
Thanks, I ended up disconnecting the battery's for a bit then hooked them backup and it started no problem.
This happend with ours, I turned the key to the on position, left it there for about 10-15 minutes, long after the theft light stoped blinking, turned it off, then started it normally.
