| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
hi, i just put new pads(front and rear) on my 2003 excursion 2wd , the truck stops fine and there are no squeeks, i bled the system with a hand powered pressure bleeder but now when i brake hard the truck pulls to the right any suggestions?? thanks ron
p.s. they are "PERFORMANCE FRICTION PADS"
the only thing i can come up with is air pressure in your tire's. probably something simple and common we're over looking.
I would manually bleed it to be safe, paing particularly close attention to the left front. that caliper if it isnt working, would cause a pull to the right..... also, what are the condtition of the rotors??? and did you lube your caliper slide pins when you put the pads on??? |
Hey man, welcome to the forum.
These guys will get you fixed up in no time. |
