Will it fit an F350? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 09-17-2007, 03:22 PM
YEAH BUDDY!
There is a local guy here that is parting out a 2001 Excursion because a tree fell on it. It is a four wheel drive, mine is two wheel drive. Will his auto trans be a direct bolt up as a replacement for mine, minus the transfer case?
Old 09-17-2007, 03:32 PM
Is the other truck Diesel?
Old 09-17-2007, 03:36 PM
YEAH BUDDY!
Oh yeah I forgot, it's a PSD
Old 09-17-2007, 03:45 PM
BIG TRUCK, SMALL DRIVER
It should work if you use a manual t-case and manual locking hubs to make things easier. You will need front wheel spacers to fit the dually wheels.
Old 09-17-2007, 03:58 PM
Strokin' In Dixie-Land
I'm lost or either misunderstood what he was asking.
Old 09-17-2007, 04:02 PM
YEAH BUDDY!
No I think pipelayer missunderstood.
I have an F350 and want to build a trans before I take one out. My truck is two wheel drive, the X is a four wheel drive. Both PSDs. Will the X trans minus the transfercase work in MY dually?
Old 09-17-2007, 04:03 PM
Nope, I'm lost, I misread his question, OOPS!
I'm not sure if the tailshafts will interchange.
Old 09-17-2007, 04:05 PM
YEAH BUDDY!
That's what I'd have to look out for? Could I measure the tailshaft to see if it's different, or is it visably noticable? I could put a different one on it if need be; right?
Bump.
I would like to know myself.
Old 09-17-2007, 04:13 PM
You would have to look at the housings and see if it can be swapped. I'm not sure if the newer trannys are designed that way. If it is a one piece case you are out of luck. Someone around here probably knows.
