Newbie what is manuf. of stock tv? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 9 Old 02-20-2012, 02:00 PM Thread Starter
hovenexcursion's Avatar
so I've been searching for hours on what kind of tv is in my x and how to turn it on. i know it sounds like a stupid question but i just bought it and the guy won't anwser my calls now. i have a 2001 x with the stock tv and vcr. there is a remote for the vcr and it turns on and plays but i don't know how to turn on the tv. maybe its broken but there is a red light by it that is on. is there another remote for it and if so who is the manufacturer of the tv so i can buy a new one or a place where i can buy a new tv that will fit in stock location so i don't have to modify anything. i also have a tv up front that i could connect to so they both play at the same time. thanks and if anyone has any suggestions please help!!!
hovenexcursion is offline
post #2 of 9 Old 02-20-2012, 03:52 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 9 Old 02-22-2012, 05:52 PM Thread Starter
Thanks I guess no one knows about the tv. how about a replacement one that will go in same spot? Please any suggestions!!
2001 X with lots of mod.s 12"lift w/40" pro comps
post #4 of 9 Old 02-27-2012, 06:34 PM
When I bought my ex the tv didn't work... I took it by a guy I know that does electronic work and he found that the ribbon where the tv swivels down was broken... he ordered a new one and I put it in. I believe he said it was an audiovox.
nvrdun is offline
post #5 of 9 Old 02-27-2012, 07:34 PM Thread Starter
Thank you thank you thank you. I will check that to and how does urs turn on? And do u have a remote for the VCR and a remote for the tv? If so can u post a pic of the tv remote. Thanks again.
post #6 of 9 Old 02-27-2012, 10:08 PM
lol vcr setup? thats old school
E99 F250 7.3 - intake, strait pipe 35" mud terrains 6.5 procomp lift ...that's all....for now
nodd89 is offline
post #7 of 9 Old 02-28-2012, 06:26 AM Thread Starter
Lol yea I know. Once I can get the tv on then I can change that out.
post #8 of 9 Old 03-07-2012, 07:05 PM
I just switch it over on the headunit and turn the vcr power on and it works for me, I would have to look for the remote. I would like to switch to a dvd unit but I don't use it much at all so I will prob leave it alone...
nvrdun is offline
post #9 of 9 Old 03-07-2012, 09:02 PM Thread Starter
Ok that might be my problem. It has an aftermarket head unit. Maybe there needs to be a switch so it sends signal to the tv letting it know turn on. I guess now I need to find out what wires r for it. If anyone has a diagram for it or knows a site, I would appreciate it. Thanks for the help!
