| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Tried disconnecting mine and caused the check engine light to come on.
What size resistor can I use to eliminate this problem? Which fuse can I pull to reset pcm code? Thanks guys |
Unplug batteries (both) for about 15 mins to bleed off all power left in PCM.
I had a soft code but no CEL while doing that. |
On an excursion?
I don't see why it would matter, same motor and sensor. But who knows.
Is it an actual EBPV code or another code? |
I'm thinking their is a difference but not sure.....every thread I've research showed unplugging the sensor does not throw the light on were not excursions.
Never had light come on......unplugged sensor and light came on immediately. Maybe someone had same prob with an excursion and found the fix. Btw.....its an 02 Thanks |
Either way, someone does sell a socket for the dangling plug to plug into. It's just a resistor so the PCM sees something there. Can't remember who and idk what resistance it is but there is such a thing.
Thanks bud......ill try searching some more for it.
Found plug but pricey ........ wonder what size resistor to do myself?
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips |
Had no luck yesterday searching but found the info today
![]() Here's the resistor you'll need.
This is what you'll need if your vehicle throws a code when disconnecting ebpv.
