Drilled and slotted brake rotors - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 09-09-2007, 07:30 AM
Anyone have any experience with these? My brother in law is considering making the swap if they will help with shorter braking distances and less fade. What is a fair price for a pair for the front?
Old 09-09-2007, 07:32 AM
they sure sound cool, i want some for mine, but i will wait to get the big brake kit with much larger pistons!
Old 09-09-2007, 07:44 AM
International Threat
I'm assuming you're talking about the 19.5 brakes after you upsize to 20+" rims?
I've got powerslots - they're slotted and Cyro'd... I've heard that if you get drilled AND slotted rotors that it can potentially break because it weakens the rotor and these aren't ricers... they're 7,000lb+ trucks!
Old 09-09-2007, 07:45 AM
im sure its a plus especially for towing or mountain driving..some of the site vendors can fill u in better on a price and what to expect
Old 09-09-2007, 07:49 AM
you lost me? (maintain)
Old 09-09-2007, 01:49 PM
I have slotted rotors that are Cyro'd. I got them from Mark @ DPPI. I also got the HAWK pads. The truck stops at least 20 feet shorter then it did before and it solid when towing. I got them for the front and I got the "upgraded" ones from autozone - it works QUITE well and are ALOT better then my stock "wobbly" decel's that I experienced from warped rotors!
I don't even know if slotted AND drilled rotors are available for our trucks. I have seen other posts on another site (cummins related) where they were talkinga bout the holes with the slotting deteriorating the strength of the rotor on such a heavy truck.
Old 09-09-2007, 06:15 PM
Drilled rotors are only good for racing, you run them a few times and throw them away. I've seen drilled rotors on cars crack when they get hot. Slotted rotors are ok.
Old 09-09-2007, 06:17 PM
ok, thanx martin.
duct tape & zip ties
Drilled rotors tend to crack when heated up. I would stay with slotted rotors myself.
Although if you want drill and slotted you can get them but your gonna pay big money for them.
Old 09-09-2007, 06:39 PM
I have a set off of an '04 4wd with very low miles on them if anyone wants to buy them. They are raybestos powerslots. I had them on an '04 gasser and traded for an '05 PSD and I pulled them off hoping they would fit the '05 and they don't. They worked great and were well worth the money!
