Installed new OEM intercooler boot/connectors. - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 12-18-2011, 10:45 PM
It just hit me where I set these to take the picture.
Not sure if this is a typical oil collection? I installed 4 blue boots and the two orange ones under the wye pipe. I decided on OEM, s because I like how they are formed to lock into the pipe groove for the two intercooler connecting pipes. I wonder how many of the intercooler passes are flooded with oil, is there a drain?
Ill be installing my separator tomorrow, I didn't want to do the atmosphere vent for smog reasons here in Cali.
This was done to stop my oil leak, both orange connector clamps were finger tight and soaked.
Old 12-19-2011, 04:28 AM
Replacing them won't help anything unless you do the CCV mod. For emissions reasons, you can get the one from Raul@StealthAutomotive made by NCHornet.
The entire system still has oil in it. I'd pull the intercooler AFTER you do the CCV mod and clean it out too.
Old 12-29-2011, 04:27 PM
Is it possible to simply remove the intercooler and rinse it out with a simple green solution; pour it in and slosh it around?
Old 12-29-2011, 04:39 PM
Yea that's what I did. Pulled it, put soap and water in there, let it sit in the hot sun during the summer and tilted it sideways, ran lots of clean water through it, and let it dry for a good long while in the hot sun to let it dry out.
Old 12-31-2011, 08:56 PM
what dictates if the boots must be replaced? Can they be cleaned and reinstalled?
Old 12-31-2011, 10:21 PM
The orange ones were probably the only ones that needed to go. They were kinda swollen and spongy. I changed all of them for piece of mind, and just about to roll 100k.
Old 01-01-2012, 08:06 AM
How much did the OEM boots run you, if you don't mind sharing? I'm about to get some new ones as well and on the fence about riff raff or oem.
Old 01-01-2012, 10:37 AM
Bought all 6 of them through Sunrise Ford for $180 shipped.
Old 01-17-2012, 01:11 PM
That's not too shabby. Thx
