loping sound? please help - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 09-01-2007, 06:13 AM
Send a message via Yahoo to redbones36
my wifes 01 7.3 excursion will have a loping sound when it is started cold mainly in the mornings. I can rev it up and it will idle normal. If started after its been warmed up it does not lope. No codes anybody no what causes this. Thanks for your time
Old 09-01-2007, 06:15 AM
When these things are cold they make alot of noise, and they dont run too good cold, so it should be normal.
duct tape & zip ties
Engine is cold, I live in Michigan and mine does this often. It will even do this if I plug it in. But I would check your GPR and glowplugs just to be safe. I know I am going to install new glowplugs into my truck.
Also in the winter I switch to 10w30 as well.
Old 09-01-2007, 10:18 AM
We live in texas and the mornings lows are in the high 70s right now. my 2000 7.3 psd has no problems in the morning ill check the glow plugs on her excursion thanks
Old 09-04-2007, 05:37 PM
Could be a IPR going out, but most times its just older oil... FYI, the Excursions have a GPC not a GPR... Glow plug controler...
Old 09-04-2007, 05:38 PM
ADMIN AND TECH
ill agree with the ipr problem, may be sticking cold
