Is this a good deal? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 11-14-2011, 01:31 PM
I'm looking at a new ex and can't decide if it's a good deal. Please help me out? What is it worth?
2001 Excursion Ltd. 4x4 7.3 Liter
Old 11-20-2011, 08:48 AM
Hey, I just bought a 2002 limited 7.3 4x4 with 65000 miles for 21k even, so with that said you could probably find a better deal, but considering the upgrades and having a newer tranny may not be too bad. Looks like a nice truck.
Old 11-20-2011, 08:51 AM
It's a fantastic deal it's even got Toyota tires!
Old 11-20-2011, 08:54 AM
Love those toyotas
It looks like a good deal since they hold value very well. I would make sure they don't have a K&N or type "cold air intake" but it looks good.
Old 11-20-2011, 09:55 AM
it has a COLD AIR INTAKE and toyota open countrys !!! wow nice...... lol on a serious note it looks good =]
Old 11-20-2011, 10:23 AM
It does have a k&n. What does that mean?
Old 11-20-2011, 10:27 AM
K&N is a notoriously bad name in intake systems for diesel engines. Holes in filters are too large in a lot of cases. These holes let too much dirt/dust in and may lead to engine dusting. Typically this is only the case with stock replacement filters and not with complete intake systems but I'm not an expert.
Old 11-20-2011, 10:40 AM
I'd be sure to check the turbo wheel and shaft for any large chunks missing and also for any scraping on the side of the housing. For the shaft, grab it and and push it in/out and up/down and make sure it is solid and doesn't hardly move at all. It has very small tolerances for movement. If it is eaten up, then you could get him to knock a thousand or more off the price for potential engine damage (check the amount of blowby) but also for a potential new turbo and labor. It wouldn't cost you that much but if you can get that much off cause of it do it.
Old 11-20-2011, 10:41 AM
what he said ^^^^^ a K an N filter filters by oil and if no one every services the filter (clean and re-oil) then its basicly letting dust etc.... into the motor i wanted to buy one but just decided to use a 6637
Old 11-20-2011, 10:55 AM
Should this scare me away from it
