Running Ds on a 00 7.3 Exc. - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 8 Old 11-14-2011, 01:14 AM Thread Starter
JMM_MD's Avatar
Is anyone out there running load range D tires on their Exc? I was just out cleaning up after putting new wheels and tires on the 00 Exc when I noticed that the tires that they just mounted were Ds and not Es. I ordered Es and will see what my options are from the tire store that I went through, but am wondering if I really have anything to worry about. I have a buddy that tried runing Cs on a 2500 Surbaban and had problems.
The Exc is a 7.3 4X4 that sees mild off roading but is mostly highway.
See Ya!
JMM_MD
00 Exc.
99 250SD
JMM_MD is offline
post #2 of 8 Old 11-15-2011, 08:42 AM
I was thinking of getting D rated tires too, but from what I understand, you have to pay attention to the rated load capacity of the tire, and see if that will be withing the limits neccesary for your application. The D's that I was looking at are 3,305 lbs per tire, which is plenty, since I don't tow too much with it at all. Any other opinions are welcome, even ones that call me an idiot, just back it up with some facts
Meat_Puppet is offline
post #3 of 8 Old 11-15-2011, 01:46 PM
chevelless414's Avatar
I have d rated on my factory wheels. I did not notice any real difference from my e rated. I got a great deal on the BFG A/T and factory wheels that where d rated. I just use them for the winter months and dont really tow much. If you ordered e rated why not bring them back?
2002 Excursion 7.3
6637 filter
gauges
v&b code spring swap
hellwig rear sway bar
4" mbrp exhaust
DP- Tuning
wicked wheel
ebpv delete
chevelless414 is offline
post #4 of 8 Old 11-16-2011, 12:43 AM Thread Starter
JMM_MD's Avatar
Based on my limited hunting about - it seems that I cannot find anyone that sells the BFG AT in 295X75X16 with an E rating, I can find Es in 285s but not the 295s so am starting to think that they do not come in an E rating.
See Ya!
JMM_MD
00 Exc.
99 250SD
JMM_MD is offline
post #5 of 8 Old 11-16-2011, 03:01 AM
I think the ex's came with d,s to soften the ride.
2008 6.4 f250 lariat 4wd
melmount is offline
post #6 of 8 Old 11-16-2011, 11:43 AM
looking4psd's Avatar
Quoted: 4 Post(s)
I use the D rating in 315/75 BFG At's, and will until the wife and I buy a travel trailer, then it will get E's. At that point I'll probably switch to goodyear duratrac's
looking4psd is offline
post #7 of 8 Old 03-12-2012, 06:02 PM
teacherman's Avatar
I bought my 2000 7.3 ex 4x2 new with d's. Fine for a while, but mushy sidewalls later. Factory recommended tires changed to E's and they had a recall on stock tires. E's will ride fine with a diesel sitting on them. It is a heavy beast, suburban's weight aint even close especially on the front end. If you asked for E's you should try to get them to make it right.
Good luck.
2009 F250 4X4 SCREW
2000 Ex limited 7.3 (BONE-stock)
2002 F150 SCREW FX4
2009 f150 SCREW Lariat
teacherman is offline
post #8 of 8 Old 03-14-2012, 01:22 AM Thread Starter
JMM_MD's Avatar
Yea - I would have to go to the next size up to get an E rated tire with these. Lessons learned:
Do not assume that all sizes of a tire can be had with the same ratings
Look at the tire specs for each size, looks like if I go by the specs the 295 Ds are very close to the E rated 285s.
In other words do you homework. I will be riding these out until they need to be changed and then will decide what I will do. Not sure I can get the 305 in there without rubbing, and the ride is so much better since I did the V/B spring mods with the rear sway bar and new shocks that the fact that I am on Ds does not seem to be hurting me.
See Ya!
JMM_MD
00 Exc.
99 250SD
JMM_MD is offline
